I've been trying for two days, have not been able to get my WiFi to work on Raspberry Pi 3
I've tried the Jessie Lite build from FR24, and even the full download from Raspberry site.
wpa_supplicant.conf:
update_config=1
network={
ssid="-----"
psk="------"
proto=RSN
key_mgmt=WPA-PSK
pairwise=CCMP
group=CCMP
auth_alg=OPEN
interfaces:
auto lo
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug wlan0
auto wlan0
iface wlan0 inet dhcp
pi@raspberrypi:~ $ ifconfig -a
eth0      Link encap:Ethernet  HWaddr b8:27:eb:4b:d5:3d
          inet addr:192.168.1.74  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: 2602:306:36c9:c70:e7a9:fcae:b690:40a6/64 Scope:Global
          inet6 addr: fe80::66b9:e804:a95e:8576/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:837 errors:0 dropped:0 overruns:0 frame:0
          TX packets:371 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:53193 (51.9 KiB)  TX bytes:50627 (49.4 KiB)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:13776 errors:0 dropped:0 overruns:0 frame:0
          TX packets:13776 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:1145608 (1.0 MiB)  TX bytes:1145608 (1.0 MiB)
pi@raspberrypi:~ $ sudo ifup wlan0
wpa_supplicant: /sbin/wpa_supplicant daemon failed to start
run-parts: /etc/network/if-pre-up.d/wpasupplicant exited with return code 1
Failed to bring up wlan0.
pi@raspberrypi:~ $ sudo ifdown wlan0
ifdown: interface wlan0 not configured
completely confused, please help. Thanks, Brian.
Hi Joe,, the Flight Radar 24 dist is built on Raspbian Jessie light here is the lsmod
pi@raspberrypi:~ $ lsmod
Module                  Size  Used by
bnep                   10340  2
hci_uart               17943  1
btbcm                   5929  1 hci_uart
bluetooth             326105  22 bnep,btbcm,hci_uart
cfg80211              427855  0
rfkill                 16037  3 cfg80211,bluetooth
ir_xmp_decoder          2903  0
ir_lirc_codec           4863  0
lirc_dev                8310  1 ir_lirc_codec
ir_mce_kbd_decoder      3921  0
ir_sharp_decoder        2177  0
ir_sanyo_decoder        2433  0
ir_sony_decoder         2175  0
ir_jvc_decoder          2173  0
ir_rc6_decoder          2813  0
ir_rc5_decoder          2493  0
ir_nec_decoder          2621  0
r820t                  16592  0
rtl2832                11329  0
i2c_mux                 2457  1 rtl2832
dvb_usb_v2             13297  0
dvb_core               81104  2 rtl2832,dvb_usb_v2
rc_core                16468  12 ir_sharp_decoder,ir_xmp_decoder,lirc_dev,ir_lirc_codec,ir_rc5_decoder,ir_nec_decoder,ir_sony_decoder,ir_mce_kbd_decoder,ir_jvc_decoder,dvb_usb_v2,ir_rc6_decoder,ir_sanyo_decoder
joydev                  9024  0
snd_bcm2835            20511  0
snd_pcm                75698  1 snd_bcm2835
snd_timer              19160  1 snd_pcm
bcm2835_wdt             3225  0
snd                    51844  3 snd_bcm2835,snd_timer,snd_pcm
spi_bcm2835             7286  0
bcm2835_gpiomem         3040  0
evdev                  11396  3
hid_logitech           20832  0
ff_memless              4750  1 hid_logitech
uio_pdrv_genirq         3164  0
uio                     8000  1 uio_pdrv_genirq
ipv6                  347530  32
and the lsusb:
pi@raspberrypi:~ $ lsusb
Bus 001 Device 006: ID 0bda:2838 Realtek Semiconductor Corp. RTL2838 DVB-T
Bus 001 Device 005: ID 046d:c06a Logitech, Inc. USB Optical Mouse
Bus 001 Device 004: ID 046d:c517 Logitech, Inc. LX710 Cordless Desktop Laser
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Looks like your WiFi adapter's driver didn't load. This is frequently due to missing firmware. You may want to check your /lib/firmware/brcm folder: if it's missing or empty, try putting these files there and reboot. You might also try to load the driver manually:
sudo modprobe brcmfmac
If that won't help, check dmesg output for clues (e.g. use grep to search for keywords like "wlan", "mac", "firmware", "error"). Those messages are often clear enough to figure out what's wrong.
Dmitry Grigoryev
  • 27,928
  • 53
  • 144
Follow https://www.raspberrypi.org/documentation/configuration/wireless/ or just these pictures.
Click on this button in the upper right corner.
Select your network.
Enter the correct passphrase.
After some seconds you're done. On the next boot you will be connected automatically.
Also check what changes were made to /etc/wpa_supplicant/wpa_supplicant.conf.
Without a GUI, it works like this:
Edit /etc/network/interfaces to make the wlan0 entry look like this:
allow-hotplug wlan0
iface wlan0 inet manual
Shutdown wlan0 and scan for APs:
sudo ifdown wlan0
sudo iwlist scan
      Cell 02 - Address: F0:D1:A9:FF:FF:FF
                Channel:11
                Frequency:2.462 GHz (Channel 11)
                Quality=44/70  Signal level=-66 dBm
                Encryption key:on
                ESSID:"MOB 4"
Add the AP to /etc/wpa_supplicant/wpa_supplicant.conf:
network={
    ssid="MOB 4"
    psk="not my real psk"
    key_mgmt=WPA-PSK
Start wpa_supplicant:
sudo /sbin/wpa_supplicant -s -B -P /run/wpa_supplicant.wlan0.pid -i wlan0 -D nl80211,wext -c /etc/wpa_supplicant/wpa_supplicant.conf
ott--
  • 189
  • hello ott, this version of raspbian (jessie lite) doesn't have a gui – Brian Tucker Jul 10 '16 at 15:05
  • @BrianTucker I've edited my answer to include a non-GUI solution. – ott-- Jul 10 '16 at 16:07
  • thanks ott, checked the changes got the following pi@raspberrypi:~ $ sudo ifdown lan0 ifdown: interface lan0 not configured pi@raspberrypi:~ $ sudo iwlist scan lo Interface doesn't support scanning.
    I'm beginning to wonder if I don't have a bad Pi3, this is from Vilros - anyone know of any diagnostics I could run?
    – Brian Tucker Jul 10 '16 at 16:17
  • @BrianTucker What do you get from ifconfig wlan0 and iwconfig wlan0 (maybe needs sudo)? – ott-- Jul 10 '16 at 16:24
  • pi@raspberrypi:/sbin $ sudo ifconfig wlan0 wlan0: error fetching interface information: Device not found
    pi@raspberrypi:/sbin $ sudo iwconfig wlan0 wlan0 No such device
    – Brian Tucker Jul 10 '16 at 16:52
  • @BrianTucker Make at least the change in /etc/network/interfaces, then make a shutdown, remove the USB power and wait some minutes before powering up again. – ott-- Jul 10 '16 at 17:11
  • FOLKS, it appears that my RPI3 was bad, I ordered a new one...and it works, so I'll send the old one back to Amazon. Thank you for all the help -I learned a lot! – Brian Tucker Jul 11 '16 at 03:45
