I'm trying to switch my Raspberry Pi 2 to the raspbian kernel rather than the one from raspberry pi foundation (found in raspberrypi-bootloader package).
I installed the linux-image-rpi2-rpfv package, which gave me the appropriate files in /boot:
/boot/System.map-4.4.0-1-rpi2
/boot/vmlinuz-4.4.0-1-rpi2
/boot/config-4.4.0-1-rpi2
During installation an initrd file was generated for this kernel:
/boot/initrd.img-4.4.0-1-rpi2
I updated my config.txt to point to the new initrd:
initramfs initrd.img-4.4.0-1-rpi2
And the boot worked fine, but booted the old kernel (kernel7.img, 4.4.11-v7+), since that is still the default. So I set the kernel parameter in config.txt to point to the new kernel:
kernel=vmlinuz-4.4.0-1-rpi2
And I get stuck with the fullscreen rainbow square indicating a boot issue.
I've tried regenerating the initrd file with update-initramfs -u but since the default kernel boots fine I doubt that's where the issue is.
This is the contents of my cmdline.txt:
dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 elevator=deadline root=/dev/mmcblk0p2 rootfstype=ext4 fsck.repair=yes consoleblank=0 rootwait fastboot noswap
This is the full config.txt that fails:
gpu_mem=512
force_turbo=1
avoid_pwm_pll=1
v3d_freq=400
disable_overscan=1
framebuffer_depth=32
framebuffer_ignore_alpha=1
framebuffer_swap=0
hdmi_force_hotplug=1
Any hints on how to actually boot the kernel from the linux-image-rpi2-rpfv package?
