I'm working a lot with ALSA and I don't know what I did wrong but when I record with:
arecord --channels=1 --duration=5 --format=dat --vumeter=stereo test.wav
...and play it back I only get some noise, whereas it worked before.
So I reset ALSA with:
sudo /etc/init.d/alsa-utils reset
sudo /etc/init.d/alsa-utils restart
A message indicates that I reset ALSA successfully
[ ok ] Resetting ALSA...done.
But I still have noise when I play back what I have recorded. What could be causing the noise, and how do I get rid of it?
goobering
  • 10,730
  • 39
  • 64
Greg Tom
    Please read the answer here, http://raspberrypi.stackexchange.com/questions/4638/sound-recording-using-python/9829#9829 – Sufiyan Ghori Oct 16 '16 at 23:51
Try using alsamixer, you may have a source that is on making all that noise. You can mute individual sources using this app.
tlhIngan
  • 3,372
