May I know which is the best to use on a Raspbery Pi USB slot: a LOGITECH 15MP 1080P HD WEBCAM C920, a LOGITECH HD Pro Webcam C910 or a LOGITECH Webcam C525 8MP HD? I need this info because I am not sure which one is good for a home automation system. Thanks
Asked
Active
Viewed 265 times
Here is somebody using the C920 with a Raspberry Pi.
Here is somebody using the C910 with a Raspberry Pi.
Here is somebody using the C525 with a Raspberry Pi.
General advice, do not use a USB webcam on a Raspberry Pi. Find a suitable camera that can use the dedicated camera port, it will take a huge load off the CPU. See here.
Good answer. Of course, if you really want 15 MP resolution and are willing to accept the processor load, then a webcam is probably your only choice. Although USB video is supposed to be standardized at this point, do search around first to make sure there is a working linux driver because to the extent that a camera does not adhere to or extends the standard, someone has to reverse engineer a driver for it, since manufacturers rarely provide them in digestible form. – goldilocks Jun 05 '16 at 11:20
A Raspberry Pi Camera Module V2 would be a good option, as they don't require as much power (both electrical and processing power), and they have a smaller footprint than most USB webcams.
Caleb Evans
- 142
- 13
