How can I set up a USB HDD to extend the life of my SD Card and maximize the performance of my Raspberry Pi?
Asked
Active
Viewed 7,520 times
14
If you're going to have a HDD that's always attached to the Pi, then you can mount the sections of your filesystem that incur the largest number of read/writes directly from it.
These directories are probably the culprits:
/home/
/var/
/tmp/
You are able to mount partitions on your external hard drive to these directories automatically at boot. Let's say your HDD is /dev/sdb
, and it has four partitions. You can append your /etc/fstab
to look something like this:
/dev/sdb1 /var ext4 defaults 0 1
/dev/sdb2 /home ext4 defaults 0 1
/dev/sdb3 /tmp ext4 defaults 0 1
/dev/sdb4 none swap sw 0 0
I've also included a swap partition. Though you might want to research how effective swap can be over USB. I really wouldn't expect much from it.
More information about swap in this question: How to set up swap space?
Would you add a swap partition/file to the HDD (assuming it was not an SSD) and if so how? – Steve Robillard Jun 18 '12 at 22:15
I probably wouldn't bother with swap. It's not going to be very quick over USB. But by all means try it out. I'll edit my answer. – Jivings Jun 18 '12 at 22:17
1I wonder if the pi will continue to boot when the USB HDD is disconnected? – faulty Jun 11 '13 at 12:29
