I have a problem with raspberry pi 3, Model B conecting Wifi. I have the raspberry 3 display 7" where I can see if wifi is connected.
When disconnect and reconnect the ethernet cable, wifi works. When I reboot with
sudo reboot
wifi works perfectly too, and I can reboot like this whenever I want and wifi works.
However, when I reboot using
sudo shutdown
and then power cycling the RPi, wifi doesn't work.
The file /etc/wpa_supplicant/wpa_supplicant.conf:
network={
ssid="My_wifi_name"
psk="Password"
Some idea?
sudo shutdownand after I put on raspberry the wifi isn't autoconnect to wifi. And I don't know why but when I rebootsudo rebootwifi works fine. What's difference between reboot and shutdown/wake up to wifi autoconnect? – DevAll Jun 02 '16 at 06:30
