I know that my question may look like trivial, but I spent 2 weeks for it and don't see any solution. I have a Raspberry Pi 2 with EDUP EP-N8508GS wifi dongle and want to setup wifi connection. The dongle was detected by system. I also can find desired hotspot with sudo iwlist wlan0 scan Here is my output of some commands:
pi@raspberrypi:~ $ lsusb
Bus 001 Device 006: ID 0bda:8176 Realtek Semiconductor Corp. RTL8188CUS 802.11n WLAN Adapter
Bus 001 Device 005: ID 046d:c312 Logitech, Inc. DeLuxe 250 Keyboard
Bus 001 Device 004: ID 046d:c050 Logitech, Inc. RX 250 Optical Mouse
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
pi@raspberrypi:~ $ cat /etc/network/interfaces
auto lo
iface lo inet loopback
iface eth0 inet manual
auto wlan0
allow-hotplug wlan0
iface wlan0 inet dhcp
# address 192.168.1.100
# netmask 255.255.255.0
# gateway 192.168.1.1
allow-hotplug wlan1
iface wlan1 inet manual
pi@raspberrypi:~ $ sudo cat /etc/wpa_supplicant/wpa_supplicant.conf
country=GB
update_config=1
network={
ssid="ASUS"
psk="MYPASSWORD"
id_str="edup"
pi@raspberrypi:~ $ sudo iwlist wlan0 scan
wlan0 Scan completed :
Cell 01 - Address: 00:26:18:C3:BA:22
ESSID:"ASUS"
Protocol:IEEE 802.11bg
Mode:Master
Frequency:2.462 GHz (Channel 11)
Encryption key:on
Bit Rates:54 Mb/s
Quality=96/100 Signal level=66/100
pi@raspberrypi:~ $ uname -a
Linux raspberrypi 4.4.9-v7+ #884 SMP Fri May 6 17:28:59 BST 2016 armv7l GNU/Linux
pi@raspberrypi:~ $ find /lib/modules | grep 8192cu
/lib/modules/4.4.9-v7+/kernel/drivers/net/wireless/realtek/rtl8192cu
/lib/modules/4.4.9-v7+/kernel/drivers/net/wireless/realtek/rtl8192cu/8192cu.ko
/lib/modules/4.4.9+/kernel/drivers/net/wireless/realtek/rtl8192cu
/lib/modules/4.4.9+/kernel/drivers/net/wireless/realtek/rtl8192cu/8192cu.ko
pi@raspberrypi:~ $ lsmod
Module Size Used by
bnep 10340 2
bluetooth 326105 5 bnep
cfg80211 427855 0
rfkill 16037 4 cfg80211,bluetooth
8192cu 519156 0
evdev 11396 4
snd_bcm2835 20511 1
snd_pcm 75698 1 snd_bcm2835
snd_timer 19160 1 snd_pcm
snd 51844 5 snd_bcm2835,snd_timer,snd_pcm
bcm2835_gpiomem 3040 0
bcm2835_wdt 3225 0
uio_pdrv_genirq 3164 0
uio 8000 1 uio_pdrv_genirq
i2c_dev 5859 0
fuse 83461 3
ipv6 347530 48
