I was messing around with my raspberry pi and i managed to delete my toolbar. I managed to get everything back but the start button. How do I get it back??
Assuming you're using LXDE (wheezy/debian default Window Manager on RPi, as explained by goldilocks):
In your home directory (/home/pi
) there is a directory called:
.config/lxpanel
(mind the dot before config, the full path is /home/pi/.config/lxpanel
When you rename or remove this directory it will be re-created on the next startup of X, using the default values. That should bring everything back to the default situation. If you renamed this directory, you can put back the changes you actually want.
use "rm -rf directory_name" (without quotes) command to delete the directory – Tarik Sep 09 '16 at 20:13
This is not a direct answer to your question (hopefully you do get one) but a little bit of explanation that might help you to solve questions like this yourself. It seems to me a lot of people are coming to the pi with little or no previous linux experience and this would be a good idea.
Operating systems you may be more familiar with (eg, windows) have a unified graphical desktop that is always the same. There are no alternatives, so, eg, configuring the taskbar on one windows system is exactly the same on other.
Linux has no universal standard desktop environment. The Xorg server, which is universal, provides the basic facilities for a windowed GUI, but it has nothing to do with taskbars, titlebars, various other widgets etc. These are the domain of the window manager (WM) and/or the desktop environment (DE). There are lots of both available, the more popular DEs that might be familiar from ubuntu, fedora, and so on include GNOME, KDE, and XFCE.
Some of them are very ornate, with animated docks, transparent overlays, multiple desktops accessed by a crazy spinning cube, etc. but that stuff would just bog the pi down, so the pi specific distributions like raspbian sensibly opt by default for a more simple and resource light DE; in the case of raspbian it is LXDE.
You can in fact install and use a completely different DE (or WM) with raspbian, I am not sure what is all in the repo (it has FVWM, which is my preference, so I have not looked beyond that).
Anyway, LXDE has a wiki, which would be a good place to look for answers to questions like this. The "help and support" link there led me to the forum which appears active and I would bet already has a few savvy pi users skulking around ;)
- 58,859
- 17
- 112
- 227
I also lost the Menu button on the tool bar and there is no easy way to get it back. I ended up using a terminal to copy the root panel to a shared area, then copied the panel to the user pi.
- Ctrl+Alt+F1 to get a terminal
- login as root
cd ~/.config/lxpanel/LXDE-pi/panels
cp panel /usr/share/lxpanel/
- reboot
- login as pi
cp /usr/share/lxpanel/panel ~/.config/lxpanel/LXDE-pi/panels/
I had this problem as well. I couldn't get back my original panel, but I managed to replicate it by simply right-clicking where it was, then going onto "Panel Settings", on "Geometry" click bottom left. Then go to "Panel Applets" and add Spacer, Menu, Desktop Numbers, and just experiment till you find the ones you want.
- 21
The logo you are looking for is at usr/share/raspberrypi-artwork/raspitr.png
Then right click the taskbar, panel preferences, panel applets, click the "menu" applet, click preferences, and enter the above path/filename for the icon location.
The icon changes back to the raspberry logo that was there originally.
- 2,740
- 4
- 23
- 36
- 21
I used Ctrl Alt f1 to start a terminal window typed cd ./config
Typed ls
This listed files including “lxconfig”
Type suspend lxconfig
Power down. Power up all good
I just suffered the same fate. Lost the raspberry, etc. I took a fresh install of raspi 32 bit and simply right clicked on the top bar of the screen and looked at the panel items (add/remove). The list begins with menu, so with menu highlighted, I clicked on Preferences and noticed that Icon read start-here and padding was set to 4. I went to the other computer with no raspberry and made the changes and....voila, the start menu and raspberry came back...tada. Continue to replicate the items in the same order and restored everything back to LIKE a NEW install. I got back all my browser links and everything is great again. I hope this helps some other newbies like me.
To get panel back I followed the below steps:
Open terminal (if no shortcut for Terminal, No worry), then right click on "Trash" icon click on "Open in terminal"
Run
sudo su
Create new user, like this:
useradd test password <your password>
Run
pkill x
Log in with test user. NOTE: once you have successfully logged in, reboot your Pi. After reboot the Pi will directly logged in as the "pi" user.
Open your terminal again (as in step 1).
Run
cd .confing
Run
cp -R /home/test/.config/lxpanel .
NOTE: Just confirm once the owner of the "lxpanel"
following is expected result:
drwxr-xr-x 3 pi pi 4096 Dec 10 12:24 lxpanel
If not, then issue the follow command. Remember that you should use the "root" or "pi" user to do these steps:
chown -R pi:pi lxpanel
reboot
- 6,308
- 3
- 23
- 38
When you right click on your panel you have the option to add applets. You simply need to add the menu and you will have it back.
But the icon for the menu will no longer have a picture of a raspberry, it will be a picture of a monitor/pc screen . Click on that and you will find all of the things you originally found on the default icon for menu.
- 2,929
- 3
- 25
- 34
I had tried a number of these suggestions but found a very simple solution. The TV I was using with hdmi had the overscan option as most TV's do. I didn't have to do anything to the raspberry. All I had to do was turn off overscan on the tv. It's easy to find out how to do this by playing with the tv menus or by going to the tv manual online. Now everything is working beautifully.
- 11
Unfortunately all of the above didn't work for me but what I did was even easier fixing lxpanel.
sudo su
apt-get purge lxpanel
apt-get autoclean
apt-get install lxpanel
Then restart Raspbian. After restart, go to Application Menu/Custormize look and feel to customize the Theme.
- 156
- 4
- 16
Open Terminal : Press
Ctrl + Alt + T
Type in Terminal :
rm -r ~/.config/lxpanel
Type in Terminal :
sudo service lightdm restart
