I am using a Pi2 with Wifi USB Wifi Adapter. Every time I boot, I have to connect to the wifi manually by providing the password. Is there any way Pi2 can automatically connect to the wifi on boot?
When I boot up, only Wifi Dongle is connected, not the ethernet cable.
My settings are as follows.
/etc/network/interfaces
auto lo
iface lo inet loopback
auto eth0
allow-hotplug eth0
iface eth0 inet static
address 192.168.40.201
netmask 255.255.255.0
network 192.168.40.0
broadcast 192.168.40.255
gateway 192.168.40.1
dns-nameservers 4.2.2.2
auto wlan0
allow-hotplug wlan0
iface wlan0 inet manual
iface default inet dhcp
auto wlan1
allow-hotplug wlan1
iface wlan1 inet manual
update_config=1
network={
ssid="Cisco09589"
psk="password"
key_mgmt=WPA-PSK
OS and Kernel version
pi@raspberrypi ~ $ cat /proc/version Linux version 4.1.19-v7+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #858 SMP Tue Mar 15 15:56:00 GMT 2016
pi@raspberrypi ~ $ lsb_release -a No LSB modules are available. Distributor ID: Raspbian Description: Raspbian GNU/Linux 8.0 (jessie) Release: 8.0 Codename: jessie
pi@raspberrypi ~ $ cat /etc/os-release PRETTY_NAME="Raspbian GNU/Linux 8 (jessie)" NAME="Raspbian GNU/Linux" VERSION_ID="8" VERSION="8 (jessie)" ID=raspbian ID_LIKE=debian HOME_URL="http://www.raspbian.org/" SUPPORT_URL="http://www.raspbian.org/RaspbianForums" BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
Ashwin Pajankar
  • 183
I had the same issue when I once configured the wifi through the preinstalled GUI. There was no other chance than reinstall raspian and make the whole configuration with /etc/network/interfaces.
I would recommend not using the /etc/wpa_supplicant/wpa_supplicant.conf but instead put your wifi password and name into your configuration directly.
This would be my configuration with a static IP address to easily connect with your PI via ssh:
auto lo
iface eth0 inet dhcp
auto wlan0
allow-hotplug wlan0
iface wlan0 inet static
    address 192.168.0.198
    network 192.168.0.1
    broadcast 192.168.1.255
    gateway 192.168.0.1
    wpa-ssid "WIFINAME"
    wpa-psk "WIFIPASSWD"
Don't forget to restart your wifi, after you made your changes!
scherzkrapferl
  • 393
I tried half a dozen tutorials using wpa-supplicant, iw and /etc/network/interfaces. But they all did not work for me. Probably because they did not describe at all what they were doing. So I always ran into a point where it did not work and there was no error message nor any way to find out the source of the problem.
Finally I simply tried installing the default network-manager. Which happens to be the gnome-network-manager but without any GUI part.
So in short, the solution is:
sudo apt --no-install-recommends install network-manager
nmcli connection add ifname wlan0 type wifi ssid <Your-SSID>
nmcli connection edit wifi-wlan0
While editing the config file you have to set WPA-PSK and the plain text password:
nmcli> goto wifi
nmcli 802-11-wireless> set mode infrastructure
nmcli 802-11-wireless> back
nmcli> goto wifi-sec
nmcli 802-11-wireless-security> set key-mgmt wpa-psk
nmcli 802-11-wireless-security> set psk <your-plain-text-password>
nmcli 802-11-wireless-security> save
nmcli 802-11-wireless-security> quit
After that reboot and enjoy! The network-manager will take care of everything!
If it complains about permission, the recommended way seems to be to modify/overwrite the policykit rules from /usr/share/polkit-1/actions/org.freedesktop.NetworkManager.policy. I gave up on that and used sudo instead. If anybody knows a clean way to do it, tell us please!
Here is a very good guide, but it's in german: https://wiki.ubuntuusers.de/NetworkManager/NetworkManager_ohne_GUI/
JPT
  • 121
Your current wlan0 configuration requires manual IP setup (like for eth0 in this file or via ifconfig like command). I hope you are using DHCP, so replace string "iface wlan0 inet manual" with "iface wlan0 inet dhcp".
nab
  • 121
