I have little to no experience with any form of computer software coding/editing but I have managed to get EmulationStation working (sort of) on my Raspberry Pi 2. I have a bought a fan and plugged it into my Pi but the problem is that when I shutdown the Pi the fan will continue to spin unless I completely unplug my system. I don't want to have to plug and unplug a wire every time I use my Pi so I was wondering if there is a command that I could enter through the terminal interface somehow to make the fan turn off when I select shutdown from the EmulationStation menu. Agagin I want to emphasise that I have very little understanding of computer brains so a step by step answer would be easiest for me to understand. Thanks.
1"I have little to no experience with any form of computer software coding/editing" -> So based on this was there actually an operating temperature issue? If the answer is "I don't know" probably the best idea, if you find the fan irritating, is to remove it. It does not serve any purpose that it hasn't already served (suckering a few consumers out of a few dollars). – goldilocks Apr 28 '16 at 23:06
Depending on the fan, it could also be potentially dangerous for the Raspberry Pi the way you have it connected. If you insist on powering it from the Raspberry Pi, the proper way to do it - given the resistance of the fan is large enough to limit the current it draws; otherwise include one - would be by using a transistor, as seen in the schematic I created below (fan is represented by the coil):
After the Raspberry Pi has booted up, you should run something like this in the terminal:
echo 12 > /sys/class/gpio/export
echo out > /sys/class/gpio/gpio12/direction
echo 1 > /sys/class/gpio/gpio12/value
And once you want to turn the fan off, just before shutdown:
echo 0 > /sys/class/gpio/gpio12/value
That is one way to do it, there are of course numerous others to toggle the GPIO pins, a quick googling can give you alternatives.
- 233
- 7
Hello! R2 is just to limit the current in case the fan's resistance is too low. As I am saying above "given the resistance of the fan is large enough to limit the current it draws; otherwise include one". – DimP Apr 28 '16 at 22:42
The fan is unlikely to run on <50mA. Ditch the series resistor. The fan probably has a brushless motor but you should still include a flyback diode. There is no need for the 47kΩ resistor (but it does no harm). – Milliways Apr 29 '16 at 00:54
The 100Ω resistor is just an indication, but you are right, I will change the value. I still believe a series resistor is needed (5Ω-10Ω), as otherwise the fan could draw too much current.
You are right on the flyback diode, will add this.
Why don't we need the 47kΩ? Does the Raspberry Pi have internal pull-downs? Because it is usually a good practice to use a pull-down at the base, even with BJTs. (ref: http://electronics.stackexchange.com/questions/56010/why-pull-base-of-bjt-switch)
– DimP Apr 29 '16 at 08:57 -
If it is a 5V fan it needs 5V to run. If you put a resistor in series it will get a lower voltage. With 100Ω it is unlikely to run. No it is not "good practice" all the 47kΩ does is reduce the drive. As an Electrical Engineer with 50 years experience I can assure you it is unnecessary. The supposed reason "helps to turn the BJT off fast(sic)" is spurious. In this case speed is irrelevant, but if you (for some reason) you want to speed up switching use an active pulldown. Effectively when the Pi output goes low the 4.7kΩ is effectively connected from base to Gnd. – Milliways Apr 30 '16 at 02:28
I am not talking about speed, I am talking about what is the correct way to do it in the general case. Do you have some reference explaining why it is better to leave the BJT base in the tristate instead of pulling it down? Because as far as I know, after the raspberry pi shuts down, the GPIOs are not still connected to the ground. It may not have a big effect here, but in a different scenario, some parasitic current could cause problems. – DimP Apr 30 '16 at 19:07
You haven't said how you are powering the fan. "I have a bought a fan and plugged it into my Pi" is vague.
Given that it stays on I reckon it's safe to assume you have connected it to a 5V pin and a ground pin. These pins are not GPIO, they are not switchable, they are powered as long as the Pi is powered.
So the answer to your question is no, there is no command to switch the fan off.
- 71,024
- 5
- 73
- 106
