21
Is there a way to adjust the brightness of the official touchscreen display? I couldn't find a definite answer. I'm running the latest release of Raspbian Jessie.
Jacobm001
  • 11,898
  • 46
  • 56
Diogo Magalhães
  • 473
The driver for the screen provides an interface through /sys/. To turn the screen on you can use the command:
echo 0 > /sys/class/backlight/rpi_backlight/bl_power
and to turn it off:
echo 1 > /sys/class/backlight/rpi_backlight/bl_power
the brightness can be adjusted using:
echo n > /sys/class/backlight/rpi_backlight/brightness
where n is some value between 0 and 255.
Ghanima
  • 15,855
  • 119
Jacobm001
  • 11,898
  • 46
  • 56
    Just small typo... rpi-backlight should be rpi_backlight for the brightness – Luc Eeckelaert May 25 '16 at 20:21
    Note that the 'brightness' setting only works on v1.1 LCD hardware. on v1.0, the control is binary, < 128 are "off", >= 128 are "on" see http://raspberrypi.stackexchange.com/questions/49822/official-touchscreen-brightness – Dave Lawrence Jun 15 '16 at 14:17
    If you get "Permission denied" errors, try with sudo bash -c "echo 0 > /sys/class/backlight/rpi_backlight/bl_power" (from https://www.raspberrypi.org/forums/viewtopic.php?p=848197#p848197) – MasterScrat Apr 06 '18 at 09:54
  • What if the folder rpi_backlight or the file bl_power don't exist? It's the case with openplotter so none of this works – NaturalBornCamper Nov 01 '18 at 14:11
12
I've made a Python package for this: github.com/linusg/rpi-backlight. Now you don't need to implement this yourself anymore.
Example
(GIF is outdated because API was changed quite a bit in v2, sorry... Below example is correct )
Works basically like the above, example:
>>> from rpi_backlight import Backlight
>>> backlight = Backlight()
>>> backlight.brightness
100
>>> backlight.brightness = 50
50
>>> with backlight.fade(duration=1):
...     backlight.brightness = 0
>>> backlight.fade_duration = 0.5
>>> # subsequent `backlight.brightness = x` will fade 500ms
>>> backlight.power
True
>>> backlight.power = False
>>> backlight.power
False
It has a GUI, a CLI and a simple Python API :)
linusg
  • 442
If you like an application, you can use the code below. I'll give detailed instructions of how to use it.
  • create a new file /home/pi/brightnesschanger.py
  • copy and paste the following code into that file (Explanation: this is the program for changing brightness):
import tkinter as tk
from tkinter import ttk
MAX_BRIGHTNESS = 255 CONFIG_FILE = "/sys/class/backlight/rpi_backlight/brightness"
def runApp ():
root window
root = tk.Tk () root.geometry ('330x100') root.resizable (True, True) root.title ('Raspberry Pi 7" screen brightness')
root.columnconfigure (0, weight=1) root.columnconfigure (1, weight=3)
slider current value
current_value = tk.IntVar ()
def get_current_value (): return (current_value.get ()/MAX_BRIGHTNESS*100)
def slider_changed (event): value_percent = "{: .2f} %".format (get_current_value ()) value_label.configure (text=value_percent) try: with open(CONFIG_FILE, "w") as file: value = current_value.get () file.write (str(value)) except: print ("ERROR: Could not set brightness") #probably file does not exist
slider
slider = ttk.Scale ( root, from_=12, to=MAX_BRIGHTNESS, orient='horizontal', # vertical command=slider_changed, variable=current_value
slider.pack(expand = 'yes', fill = 'x')
current value label
current_value_label = ttk.Label (root, text='Current Value:' )
current_value_label.pack(expand = 'yes', fill = 'x')
value label
value_label = ttk.Label (root, text=get_current_value ()) value_label.pack(expand = 'yes', fill = 'x')
try: with open(CONFIG_FILE, "r") as file: value = file.readline () slider.set (int (value)) except: print ("Error: Could not read brightness")
root.mainloop ()
if (name == "main"): runApp ()
  • Save and close the file
  • Unfortunately you cannot double-click that file to run the program.
  • We will now create a file on the Desktop, that you can doubleclick to start the program
  • Open a text editor and paste the following content:
[Desktop Entry]
Version=1.0
Name=Brightness
Comment=Change brightness of Raspberry Pi 7 inch official screen
Exec=sudo python3 /home/pi/brightnesschanger.py
Path=/home/pi
Terminal=false
Type=Application
Categories=Utility
  • Save the file under home/pi/Brightness.Desktop
  • Security notice: The application will be started with root privileges. If you use your pi only for playing around, this should be no problem. Otherwise you should figure out if this is a problem for you.
DarkTrick
  • 141
