21
My Raspberry Pi 3 came with Java version 1.8.0_65 installed. I could not update it to a later version using apt-get - I assume there's no Debian repo for it. I do not know how to update it, and installing a newer version does not replace the existing one.
What's the bet way to install/update Java on Raspbian, and keep it updated going forward?
Traveling Tech Guy
  • 313
  • There's a rather fiddly process involving calling update-alternatives for each component of the JRE/JDK. Oracle doesn't provide an auto-update service, as you need to manually log in to their site to download updates.Unless this is mission critical, I'd stick with the default Raspbian oracle-java8-jdk – scruss Sep 18 '16 at 15:53
  • @traveling-tech-guy If any of the answers below, answered your question, please mark them so. If you solved it in a different way, please post an answer to your own question and mark that. – not2qubit Mar 22 '17 at 13:20
  • @not2qubit none did, I had to uninstall and re-install. See my comment to second answer. – Traveling Tech Guy Mar 22 '17 at 17:34
To have all the time the most recent Oracle java installed, you can do check current Java
pi@raspberrypi:~ $ java -version java version "1.8.0_65" Java(TM) SE Runtime Environment (build 1.8.0_65-b17) Java HotSpot(TM) Client VM (build 25.65-b01, mixed mode)
remove OpenJDK
sudo apt-get purge openjdk*
add digital key
sudo apt-key adv --recv-key --keyserver keyserver.ubuntu.com EEA14886
add packet source
sudo vim /etc/apt/sources.list
add following lines
deb http://ppa.launchpad.net/webupd8team/java/ubuntu trusty main
deb-src http://ppa.launchpad.net/webupd8team/java/ubuntu trusty main
install Java 8
sudo apt-get update
sudo apt-get install oracle-java8-installer
sudo apt-get install oracle-java8-set-default
remove old Java
sudo apt-get purge java7*
sudo apt-get autoremove
check success
java -version
pi@raspberrypi:~ $ java -version java version "1.8.0_131" Java(TM) SE Runtime Environment (build 1.8.0_131-b11) Java HotSpot(TM) Client VM (build 25.131-b11, mixed mode)
SWilk
  • 103
hannes ach
  • 246
    Great answer. I only had to notice that the command apt-key was pasted with the long dash, which at some point had to accidentally replace double dashes -- so the command did not work, and resulted in weird error: gpg: conflicting commands. I have edited the answer to correct it. – SWilk Nov 11 '17 at 20:39
    This didn't work with Rasbian Stretch. The instructions at https://gist.github.com/ribasco/fff7d30b31807eb02b32bcf35164f11f worked for me. – Kevin Doyon May 15 '18 at 03:22
  • sudo apt-get purge java7* removed oracle-java8-jdk... – Cardinal System Dec 08 '19 at 06:19
The following advice by hannes ach and SWilk was successful, but I got the following error:
pi@raspberrypi:~ $ sudo apt-key adv --recv-keys --keyserver keyserver.ubuntu.com C2518248EEA14886
Executing: /tmp/apt-key-gpghome.hVyJ3FPvDb/gpg.1.sh --recv-keys --keyserver keyserver.ubuntu.com C2518248EEA14886
gpg: failed to start the dirmngr '/usr/bin/dirmngr': No such file or directory
gpg: connecting dirmngr at '/tmp/apt-key-gpghome.hVyJ3FPvDb/S.dirmngr' failed: No such file or directory
gpg: keyserver receive failed: No dirmngr
In order to resolve that, I ran:
sudo apt-get install dirmngr --install-recommends
then
Then, everything worked as expected.
Original info from here https://blog.sleeplessbeastie.eu/2017/11/02/how-to-fix-missing-dirmngr/
Aurora0001
  • 6,308
  • 38
If you want new features now it's possible to get version 9 and 10 like this:
wget https://github.com/bell-sw/Liberica/releases/download/10/bellsoft-jre10-linux-arm32-vfp-hflt.debsudo
apt install ./bellsoft-jre10-linux-arm32-vfp-hflt.deb
Liberica for Raspberry Pi: https://www.bell-sw.com/java-for-raspberry-pi.html
Dmitry
Have you tried this guide yet? http://elinux.org/RPi_Java#Installing_Java_on_Raspberry_Pi
OpenJDK
sudo apt-get update
sudo apt-get install openjdk-7-jdk
Oracle Java 8
wget http://www.java.net/download/JavaFXarm/jdk-8-ea-b36e-linux-arm-hflt-29_nov_2012.tar.gz
tar zxf jdk-8-ea-b36e-linux-arm-hflt-29_nov_2012.tar.gz
rm jdk-8-ea-b36e-linux-arm-hflt-29_nov_2012.tar.gz
sudo mv ./jdk1.8.0/ /opt/
sudo chown root:root -R /opt/jdk1.8.0/
sudo ln -s /opt/jdk1.8.0/ /opt/jdk8
Edit sudo nano -w /etc/profile and add
PATH="$PATH":/opt/jdk8/bin
JAVA_HOME=/opt/jdk8
java -version
to see if java is working
Neckbeard2016
  • 113
    Thanks for the detailed question, but I already have Java 8 installed. My question has to do with updating to newer versions. – Traveling Tech Guy Apr 18 '16 at 14:32
  • Does not work, the apt-get installed Java is taking precedence on the path since it is in /usr/bin/java – Wim Deblauwe Aug 25 '16 at 08:52
    These are very old instructions, and are no longer valid – scruss Sep 18 '16 at 15:40
  • +1 to switch to openjdk, be it for 7 or 8 if possible. It's much easier to keep current than manually download new releases from the oracle web-page than with a simple apt. The default version can easily be switched with sudo update-alternatives --config java; sudo update-alternatives --config java and only needs to be done once. – MadMike Feb 21 '17 at 10:57
