Are there any 64-bit Ubuntu ARM images? All I can find is a 64-bit x86 image and a 32-bit ARM image, but I'd like to take advantage of the Raspberry Pi 3's 64 bit architecture. This article implies I might be out of luck. Is there any easy way to accomplish this?
4All you have to do is rewrite the kernel and all modules for 64 bit. What would you achieve seeing as memory is limited to 1GByte (apart from making the code bigger)? – Milliways Apr 10 '16 at 08:59
This question and its answers will provide some additional insight into the issue http://raspberrypi.stackexchange.com/questions/43921/raspbian-moving-to-64-bit-mode?rq=1 – Steve Robillard Apr 10 '16 at 10:12
@Milliways - I have a Dragonboard410c running Linaro 64-bit ARM Linux and it does just fine with 1GB of RAM. App and data usage can increase by going 64-bits, but it doesn't have to. Aarch64 instructions are still 32-bits each and no one forces you to store data as 64-bit ints. – BitBank Apr 10 '16 at 17:13
The foundation kernel has been ported by third parties to 64 Bit , but only by breaking HW acceleration, camera support , WiFi and Bluetooth.
Whether Canonical is interested to use this completely custom downstream kernel is an question only they themselves can answer.
Don't forget that most Raspberry Ubuntu images don't seem to be maintained and supported by Canonical at all , but by community efforts.
Of course most download pages are not thinking about AArch64 when they write "64-bit" , even Canonicals main "64-bit" download does not work on the Pi directly.
- 6,235
- 14
- 33
I'm running
Linux ubuntu 5.3.0-1012-raspi2 #14-Ubuntu SMP Mon Nov 11 10:06:55 UTC 2019 aarch64 aarch64 aarch64 GNU/Linux
right now on a Raspberry PI 4 with 4 GB of RAM.
I believe I got the image at https://wiki.ubuntu.com/ARM/RaspberryPi#Ubuntu_arm64.2FAArch64 (but I did a lot of flailing around to find it). Nevertheless, the file I flashed to the SD chips was named:
ubuntu-19.10-preinstalled-server-arm64+raspi3.img
and it booted. USB didn't work until I used ssh to login and add total_mem=3072 to /boot/firmware/usercfg.txt (there are probably smarter ways to do this). After I rebooted USB works (and thus keyboard & mouse).
Haven't figured out how to get my desktop environment installed yet...
- 2,740
- 4
- 23
- 36
- 131
- 6
