I have installed Kali Linux on my Raspberry PI2 Model B. I have also bought Raspberry PI USB Wi-Fi Dongle. When I try to put the adaptor into "monitor mode" using airmon-ng start wlan0 I get an error (ERROR adding monitor mode interface: command failed: Operation not supported (-95)). What can I do to fix it (buy a different one or something else) ?
Asked
Active
Viewed 9,344 times
Hello and welcome. Could you please be more concise with the title. The "on RPi" is not helping, as everything here is suppossed to be on the Pi. Instead try to include a very short statement of the problem, something along the line WiFi monitor mode not working, something, something. Thanks. – Ghanima Apr 05 '16 at 12:52
The Raspberry-Pi Wi-Fi adapter is based on the BCM43143 (official product description) chipset which does not support monitor mode with current drivers. (as written here).
You should try a USB WiFi Dongle that has the supporting chip-set. Then install required drivers , then use airmon-ng. This should work.
Sohan Arafat
- 1,828
- 10
- 40
I looked for different wifi dongles this one fall in the category of good and affordable: https://www.amazon.com/dp/B0035OCVO6?m=A5PVPB4WB2LS4&ref_=v_sp_detail_page
Zack
