I have Raspberry Pi which needs to read sensor data through Bluetooth and I2C. I want to know the Linux operating system which will be well suited for this application.
Asked
Active
Viewed 205 times
Most of the OS's available for the Pi would be able to meet your requirements. However, as it appears from your question that you are fairly new to the Pi I would suggest Raspbian which is based on Debian. You can download it from here. The main reason for this suggestion is that there are simply more tutorials and a bigger user base running Raspbian than the other OS's. This will make it easier to find code samples and get help when you run into problems. I would also suggest downloading the full (not lite) version as it includes the GUI making some tasks easier.
Steve Robillard
- 34,687
- 17
- 103
- 109
Thank you for your answer. Can you tell the other OS that are available for raspberry pi – user42939 Mar 31 '16 at 05:16
1If you look to the left you will see related questions including this one http://raspberrypi.stackexchange.com/questions/534/definitive-list-of-operating-systems?rq=1 – Steve Robillard Mar 31 '16 at 05:18
Does Nard SDK will be suitable for my apllication??? – user42939 Mar 31 '16 at 05:49
I have no experience with it, but unless you are already familiar with it; you will have an easier time with Raspbian. – Steve Robillard Mar 31 '16 at 05:53
