I have Arch Linux running on my Raspberry Pi 2.
Right after install, I ran lsblk, fdisk and df commands (unfortunately I did not save the output) but I had one disk, which is the SD card and two partitions on it. Then, I upgraded the system with pacman -Syu, installed sudo and configured ssh. Now, when I run fdisk it shows I have 16 RAM disks in memory with parameters:
Disk /dev/ram15: 4 MiB, 4194304 bytes, 8192 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
and all kinds of file systems mounted at various mount points (while I personally created only /dev/root and /dev/boot):
Filesystem Size Used Avail Use% Mounted on
/dev/root 1.8G 1.1G 557M 67% /
devtmpfs 458M 0 458M 0% /dev
tmpfs 462M 0 462M 0% /dev/shm
tmpfs 462M 328K 462M 1% /run
tmpfs 462M 0 462M 0% /sys/fs/cgroup
tmpfs 462M 0 462M 0% /tmp
/dev/mmcblk0p1 100M 18M 83M 18% /boot
tmpfs 93M 0 93M 0% /run/user/1000
So my question is: What are all these RAM disks and why they are in my system, since I definitely did not create them and what are those file systems mounted?
Edit:
cat /proc/partitions output:
major minor #blocks name
1 0 4096 ram0
1 1 4096 ram1
1 2 4096 ram2
1 3 4096 ram3
1 4 4096 ram4
1 5 4096 ram5
1 6 4096 ram6
1 7 4096 ram7
1 8 4096 ram8
1 9 4096 ram9
1 10 4096 ram10
1 11 4096 ram11
1 12 4096 ram12
1 13 4096 ram13
1 14 4096 ram14
1 15 4096 ram15
179 0 31472640 mmcblk0
179 1 102400 mmcblk0p1
179 2 1853439 mmcblk0p2
/proc/partitionsmay be of relevance. You should include the output ofcat /proc/partitionsin your question. – kasperd Mar 27 '16 at 17:26
