I just realised that provided you don't need to resize any partitions you can actually do it on the Mac.
WARNING Make doubly sure that you don't accidentally write in the wrong place.
The following script I wrote to rearrange Ubuntu MATE partitions and you should be able to adapt this to copy your data.
NOTE All care BUT no responsibility, and you really need to understand partitioning!
#!/bin/bash
# script to create a Ubunutu MATE image with properly aligned partitions
# 2015-11-06
echo
#INPUT_IMG="ubuntu-mate-15.10-desktop-armhf-raspberry-pi-2.img"
INPUT_IMG="PiMate1510back20151106_small.img"
OUTPUT_IMG="ubuntu-mate-15.10.img"
# Partition details of input image
P1START=2048
P1SIZE=131072
P2START=133120
P2SIZE=7546880
# Partition details of output image
P1NEW=8192
P2NEW=139264
# End of user configuration
#let IMG_END=$P2NEW+$P2SIZE+140000
echo -e $P1START - $P1NEW $P1SIZE
echo -e $P2START - $P2NEW $P2SIZE
echo -e $IMG_END
# Create an empty image file
dd if=/dev/zero of=$OUTPUT_IMG count=$IMG_END
# Create partitions
echo -e "
e 1
0C
n
$P1NEW
$P1SIZE
e 2
83
n
$P2NEW
$P2SIZE
quit" | fdisk -e $OUTPUT_IMG
echo "Finished Create partitions"
# Copy partitions
dd if=$INPUT_IMG skip=$P1START of=$OUTPUT_IMG seek=$P1NEW count=$P1SIZE
dd if=$INPUT_IMG skip=$P2START of=$OUTPUT_IMG seek=$P2NEW count=$P2SIZE
#fdisk $OUTPUT_IMG
rsyncthe contents from the original into the new smaller version. You'll need to useddandfdiskto create the new versions, see here. Beware that Milliway's scripted version is likely to loose data if the system has been used much since it does not copy the contents, it just copies raw blocks. – goldilocks Mar 26 '16 at 16:03ddcopies/moves blocks but the mapping of these blocks to physical storage is a function of the SD Card firmware (as I am sure you pointed out to me in the past when I raised the issue of data loss with another questioner) – Milliways Mar 26 '16 at 22:43dd. However, the filesystem is structured using them, and does assign them specific content. Whether they are real or virtual on the device is irrelevant. So if you have a filesystem 20 blocks in size and you've only used 7, those 7 may be dispersed. They are not necessarily 1-7. – goldilocks Mar 26 '16 at 22:51ddand copy half the blocks, you copy 1-10. Again, it does not matter whether those are "real" or "virtual" numbers with respect to the physical device. They are real to filesystem. So if 13, 14, and 19 were 3 of the 7 blocks used, you just lost 3/7 of the data in the filesystem. – goldilocks Mar 26 '16 at 22:51dduse the firmware to map blocks to physical storage. No normal userland software has access to the SD internal mapping. Produce some evidence for your outrageous statement. – Milliways Apr 01 '16 at 09:59
