I have recently acquired an RPi 3 model B. Because I do a lot of traveling I have several questions about the safety and ability of leaving a RPi active while being far away. I am not mainly concerned about leaving it up 24/7 (it is still a concern), my main concern is the use of a USB stick on boot-up. The list below highlights my main concerns:
  1. Is it safe to leave the pi on continually till I get back home? I would have a small fan blowing on the RPi to keep it cool.
  2. Can a USB stick be used on bootup without having to unplug and re-plug it in?
  3. Can I remotely connect to a pi and use its graphical interface or can I only use its terminal?
  4. Will the pi suffer any ill effects by leaving it on 24/7?
Austin Hitt
  • 59
  • Welcome to Raspberry Pi! It is preferred if you can post separate questions instead of combining your questions into one. That way, it helps the people answering your question and also others hunting for at least one of your questions. Thanks! E.g. 1) and 4) somehow relate to each other but 2) and 3) completely stand on their own. @Jacobm001, well the question would be: makes the use of a Pi-3 it different from that question? – Ghanima Mar 23 '16 at 21:18
  • @Ghanima: I'm not sure one could reasonably suspect that the answer would be different between iterations. – Jacobm001 Mar 23 '16 at 21:20
  • while the Pi cannot boot from USB stick it is perfectly capable to bootup and automatically mount said stick without user intervention.
  • – Ghanima Mar 23 '16 at 21:20
