I have a RaspBerry PI 2B running Windows IoT Core connected via an ethernet cable to the internet. Sometimes, and mostly after a reboot/power outage, it isn't able to connect with the internet. Without an internet connection the PI becomes useless to me because I'm not able to ping it, remote-control it (with PowerShell), ...
Now when I extract the SD card, burn a fresh image back on it and insert it into the PI the ethernet connection works again.
Anyone has an idea on what is causing this?
Jorn.Beyers
  • 111
  • Have you checked your router? I would guess that is the problem. – DolbyOver Mar 18 '16 at 13:53
  • What makes you think that this is a router issue? All other connected devices remain their connectivity, also other RaspBerry PI's. – Jorn.Beyers Mar 18 '16 at 14:46
  • I would ask if you could post some log files but I do not know what/where they would be on a widows-iot Pi! Can you find such things on the SD card - assuming that it hasn't been too badly corrupted when you have to switch the Pi off with dirty (or more politely, possibly inconsistent) file-systems because you can't get into it to shut it down cleanly? Obviously you want to do this before you overwrite the SD card, again! 8-) – SlySven Mar 18 '16 at 16:41
  • I have a similar problem. Did you find a solution to your problem? – Ingo Feb 16 '18 at 11:40
  • No never figured out what the problem was ... Sad to hear people are still facing this issue. – Jorn.Beyers Feb 16 '18 at 15:03
0 Answers0
