I ordered a Pi 3 and accessory kit here from Amazon, it comes with 2 heat sinks. I won't be overclocking the Pi, would I still need to worry about heat issues? Eventually, this will be in an enclosed area outside of the casing with plenty of air circulation.
1Possible duplicate of What are the cooling requirements for Raspberry Pi 3? – goobering Mar 08 '16 at 18:08
I asked a similar question here: https://raspberrypi.stackexchange.com/questions/55053/how-much-difference-do-the-stick-on-heat-sinks-make - and the enclosure is what makes the most difference. But in the end, neither changed it more than a couple of degrees. I see an answer that talks about throttling but have never noticed that, even on hot days. Still, I did order a new enclosure with a small fan, and do use the heat sinks. – SDsolar Oct 29 '16 at 17:57
You can also add a fan :P As in my answer http://raspberrypi.stackexchange.com/a/62171/56121 – UselesssCat Feb 19 '17 at 06:03
No a heatsink is not required, The Pi3 has been reported to generate more heat than previous models, but the heatsink is not required. You can install it for some extra thermal protection, but the Pi will throttle the clock speed to maintain a safe temperature. Heatsinks are included in many of these kits to increase the perceived value.
- 34,687
- 17
- 103
- 109
3I don't know how intrusive the throttling will be, or what load the OP has in mind, but I'd argue that a heatsink might be necessary to reach the necessary performance point in some scenarios - maybe mostly dictated by the 'enclosed area' or by the application... – Sean Houlihane Mar 20 '16 at 10:31
1I had this question about the RPi 3B+, so I did a before/after measurement. Without heat sinks, the CPU ran between 59C and 61C. With heat sinks, it runs between 52C and 54C. – zslayton Jun 06 '19 at 14:04
As the answers state, no heatsinks are required.
However, following on from Snowman's comment to Maxthon Chan's answer, and taking some examples from the Raspberry Pi site1, should you want to check/measure the temperature that your Pi is running at, you can use the command:
/opt/vc/bin/vcgencmd measure_temp
Should you find yourself using this command frequently, you may wish for a shortcut. To do this, you could use an alias, such as temp. To set this up, run the following commands:
cd ~
nano .bash_aliases
and add the following line
alias temp='/opt/vc/bin/vcgencmd measure_temp'
In case of error
Note that, should you be running an older version of Raspbian, and encounter the error:
/opt/vc/bin/vcgencmd: error while loading shared libraries: libvcos.so: cannot open shared object file: No such file or directory
then you should run
LD_LIBRARY_PATH=/opt/vc/lib /opt/vc/bin/vcgencmd measure_temp
and the alias would become
alias temp="LD_LIBRARY_PATH=/opt/vc/lib && /opt/vc/bin/vcgencmd measure_temp"
Alternative
Run the following command, which gives the answer in millidegrees Centigrade, and divide by 1000 to get °C:
cat /sys/class/thermal/thermal_zone0/temp
Bash script for CPU and GPU temperatures
#!/bin/bash
cpuTemp0=$(cat /sys/class/thermal/thermal_zone0/temp)
cpuTemp1=$(($cpuTemp0/1000))
cpuTemp2=$(($cpuTemp0/100))
cpuTempM=$(($cpuTemp2 % $cpuTemp1))
gpuTemp0=$(/opt/vc/bin/vcgencmd measure_temp)
gpuTemp0=${gpuTemp0//\'/º}
gpuTemp0=${gpuTemp0//temp=/}
echo CPU Temp: $cpuTemp1"."$cpuTempM"ºC"
echo GPU Temp: $gpuTemp0
1 All examples taken from Show RPI's Temperature with a command
- 2,740
- 4
- 23
- 36
It would probably be better to add a permanent entry to
ld.so.cache(eg. viasudo bash echo /opt/vc/lib > /etc/ld.so.conf.d/opt-vc.conf && sudo ldconfig) than applyingLD_LIBRARY_PATH. I think this already exists by default in current Raspbian. – goldilocks Dec 27 '19 at 14:47 -
For the temp alias to work, you need to run source .bash_aliases This will re-load the .bash_aliases file, which is what rebooting or re-logging in does, just without the wait. From: https://www.raspberrypi.org/forums/viewtopic.php?t=144613 – user112656 Dec 27 '19 at 00:48
No heatsink is required, but this does not prevent you from adding one. If your operating environment can get a bit warm and you don't want it to thermal throttle, you can add one (optionally strap a fan on it.)
I have all my Pi heatsinked since I use cases while put lots of stress on the core, and one of them have a fan strapped on it to improve cooling as it operates in a warm equipment roon with an average ambient temperature of 45ºC.
- 1,051
- 7
- 14
1This answer touches on the key point: measure its temperature if one is concerned about potential overheating. – Mar 08 '16 at 20:22
