I have looked at the WiringPi site and have found:
pwmSetRange (unsigned int range) ;
This sets the range register in the PWM generator. The default is 1024.
pwmSetClock (int divisor) ;
This sets the divisor for the PWM clock.
What does that mean? What is the PWM clock and what is meant by "range register".
nullexception
  • 29
In digital electronics, especially computing, a hardware register stores bits of information in such a way that systems can write to or read out all the bits simultaneously.
I'm not sure, but page 139 of this sounds like range N and divisor M:
A value represented as a ratio of N/M can be transmitted along a serial channel with pulse width modulation in which the value is represented by the duty cycle of the output signal. To send value N/M within a periodic sequence of M cycles, output should be 1 for N cycles and 0 for (M-N) cycles.
This answer seems to agree.
