16
I need my RPi 3 to connect to a Wi-Fi network using channel 12, but I'm not able to get the built-in Wi-Fi adapter to use this channel.
This is what I've done:
$ sudo apt-get install wireless-regdb iw crda
$ sudo iw reg set NO
$ sudo iwlist wlan0 channel
wlan0     11 channels in total; available frequencies :
      Channel 01 : 2.412 GHz
      Channel 02 : 2.417 GHz
      Channel 03 : 2.422 GHz
      Channel 04 : 2.427 GHz
      Channel 05 : 2.432 GHz
      Channel 06 : 2.437 GHz
      Channel 07 : 2.442 GHz
      Channel 08 : 2.447 GHz
      Channel 09 : 2.452 GHz
      Channel 10 : 2.457 GHz
      Channel 11 : 2.462 GHz
As you can see the list doesn't include channel 12 (or 13). Is there a way to enable channel 12 for the built-in adapter?
Update: This is what I get in dmesg:
[    5.506232] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
[    5.756813] brcmfmac: brcmf_add_if: ERROR: netdev:wlan0 already exists
[    5.756854] brcmfmac: brcmf_add_if: ignore IF event
[    5.765557] cfg80211: Calling CRDA to update world regulatory domain
[    5.867878] lirc_rpi: auto-detected active high receiver on GPIO pin 18
[    5.875184] lirc_rpi lirc_rpi: lirc_dev: driver lirc_rpi registered at minor = 0
[    5.875222] lirc_rpi: driver registered!
[    5.885249] bcm2835-rng 3f104000.rng: hwrng registered
[    5.902514] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[    6.026071] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
[    6.026108] cfg80211: World regulatory domain updated:
[    6.026124] cfg80211:  DFS Master region: unset
[    6.026141] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[    6.026173] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[    6.026197] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[    6.026211] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[    6.026246] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[    6.026277] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[    6.026307] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[    6.026332] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[    6.026345] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[    6.026421] cfg80211: Calling CRDA for country: NO
[    6.070591] cfg80211: Regulatory domain changed to country: NO
[    6.070607] cfg80211:  DFS Master region: ETSI
[    6.070613] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[    6.070621] cfg80211:   (2400000 KHz - 2483500 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[    6.070628] cfg80211:   (5150000 KHz - 5250000 KHz @ 80000 KHz, 200000 KHz AUTO), (N/A, 2301 mBm), (N/A)
[    6.070635] cfg80211:   (5250000 KHz - 5350000 KHz @ 80000 KHz, 200000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[    6.070643] cfg80211:   (5470000 KHz - 5795000 KHz @ 160000 KHz), (N/A, 2698 mBm), (0 s)
[    6.070650] cfg80211:   (5815000 KHz - 5850000 KHz @ 35000 KHz), (N/A, 3301 mBm), (0 s)
[    6.070656] cfg80211:   (17100000 KHz - 17300000 KHz @ 200000 KHz), (N/A, 2000 mBm), (N/A)
[    6.070662] cfg80211:   (57000000 KHz - 66000000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
Greenonline
  • 2,740
  • 36
perja
  • 262
    Have you set your region. Different administrations have different bands, and WiFi will not permit unauthorised frequencies. – Milliways Mar 03 '16 at 09:14
  • Yes, if I understand it correctly, this command should have set the region: sudo iw reg set NO – perja Mar 03 '16 at 10:22
  • There are probably many ways to fiddle with regional settings. Why not just use raspi-config to do it the standard way. – Milliways Mar 03 '16 at 10:25
  • Ah, yes, there is actually a "Change Wi-Fi Country" in raspi-config, but unfortunately the result is the same. – perja Mar 03 '16 at 10:54
  • Do you use /etc/wpa_supplicant/wpa_supplicant.conf? I was told to add country=GB as the first line. That worked for me and I now have channels 12 and 13. – joan Mar 03 '16 at 12:36
  • Yes, I have wpa_supplicant.conf, but it already has country=NO as the first line. Tried with GB as well, but no… – perja Mar 03 '16 at 12:58
    Okay, I also did a update/upgrade/dist-upgrade and a rpi-update and a BRANCH=next rpi-update as part of this process. I don't know if any of them were also necessary. – joan Mar 03 '16 at 13:04
    @joan: that was it! sudo BRANCH=next rpi-update and then a reboot resolved the issue. – perja Mar 03 '16 at 14:21
9 Answers9
"In normal circumstances there is NEVER a need to run rpi-update as it always gets you to the leading edge firmware and kernel and because that may be a testing version it could leave your RPi unbootable". https://www.raspberrypi.org/forums/viewtopic.php?p=916911#p916911 Even the rpi-update documentation now warns "Even on Raspbian you should only use this with a good reason. This gets you the latest bleeding edge kernel/firmware."
I've just had an identical problem. The solution, in my case, was to follow joan's suggestion from the comments underneath the question.
sudo apt-get update
sudo apt-get upgrade
sudo apt-get dist-upgrade
sudo rpi-update
[reboot]
sudo branch=next rpi-update
[reboot]
On completion, channels 12 and 13 appear in the list produced by iwlist wlan0 channel.
goobering
  • 10,730
  • 39
  • 64
    For the record: after "sudo branch=next rpi-update" kernel was update from 4.1.18 to 4.4.3 and firmware from something to 41f8b4812ad653abf321b8c54cb4bee57ebdb129 (from /boot/.firmware_revision). – perja Mar 03 '16 at 17:34
  • you made my day. – blfuentes Mar 18 '16 at 19:17
  • How do you get rpi-update command? – IgorGanapolsky Jul 18 '16 at 01:37
    @IgorGanapolsky "In normal circumstances there is NEVER a need to run rpi-update as it always gets you to the leading edge firmware and kernel and because that may be a testing version it could leave your RPi unbootable". https://www.raspberrypi.org/forums/viewtopic.php?p=916911#p916911 – Milliways Aug 04 '16 at 00:07
  • If you use channel 13 make sure you are allowed to in your region. – Piotr Kula Sep 22 '16 at 18:05
  • I tried the above and now my pi3 won't boot to desktop anymore with this error: unable to mount root FS on unknown block 179 2 – Jono Oct 01 '18 at 21:15
Following @goobering's answer didn't quite do it for me. I was able to update my firmware but once I tried running sudo branch=next rpi-update it told me I was already at the latest. I was not.
Using @perja's firmware hash (below the original answer) I ran;
sudo rpi-update 41f8b4812ad653abf321b8c54cb4bee57ebdb129
This got me from 4.1.18 to 4.4.3.
This means (for me at least) the complete steps were;
sudo raspi-config (set Wifi Country to GB, or a country that works for you)
sudo apt-get update
sudo rpi-update
shutdown -r now
shutdown -r now
And viola, I can now see channel 12!
I have a feeling you could roll up those rpi-updates into one command but it feels safer to grab the latest master first, do a succesful reboot then try 4.4.3.
The bootup time on the 3 is so quick anyway ;-)
Related blog post
Toby
  • 151
The solution by Shan-Desai works well, but I encountered a problem while implementing it.
When I wanted to set the Wlan channel, I was getting an error stating that the device is in use and busy. But after turning the device off and back on again [software-wise] the problem went away. So what I did is the following
$ sudo iw reg set CA
$ sudo ifconfig wlan0 down
$ sudo ifconfig wlan0 up
$ sudo iwconfig wlan0 channel 11
Another matter to make note of is the fact that channel changes reset to default upon each reboot of the RPi. So in order to keep those changes on your RPi, I would suggest writing a shell script in the root directory and calling it in crontab upon reboot. I did so by
$ nano wlan0_setup.sh
and populate the file by the following:
I then saved the file and made it an executable shell script by running
$ sudo chmod +x /home/pi/wlan0_setup.sh
Now that the script is executable by running
$ sh wlan0_setup.sh
we can add it in the crontab by executing
$ crontab -e
when the crontab opens, go to the end of the file and add the following
@reboot sh /home/pi/wlan0_setup.sh
then save and exit the editor. By doing so, the wlan0_setup.sh script will run upon each and every reboot of the RPi.
I hope this helps, wish you all luck.
Babak D
Reporting in from the future - (where the raspian kernel is 4.9) I can tell that sudo raspi-config now offers a option Set wifi country under localization. From there you can set a locale that enables the channel 12 and 13.
LudvigH
  • 133
Thanks for the reply Toby, it seems the SHA-1 commit hash as an argument to rpi-update command was necessary to update firmware to the make it working to see channel 12 and 13.
But I also have to thank to Shan-Desai as setting up the country code using iw reg set $COUNTRYCODE command was very important part of the process as well - without this settings there were only 11 channels allowed/visible all the time as the default and the set country code was 00 (not sure whether this one really belongs to any country or whether it was just "safe setting" for all countries around the world).
Mig
I use the first solution (goobering), and it didn't work.
After search on the Internet, I found these might be help. All you need to do is install crda and set the wifi region.
https://www.raspberrypi.org/forums/viewtopic.php?t=36961#p308569 RPI 3 doesn't see my wifi
If you use wpa_supplicant, you have to change country in /etc/wpa_supplicant/wpa_supplicant.conf
Peter Lai
  • You do not need to install any software. Just with sudo iw list all channels 1 to 14 are listed on Raspbian Stretch and Buster. – Ingo Aug 21 '19 at 08:47
The channels are set by your wireless access point, and the country you live in. USA only has 12 distinct channels. Some countries have 14... not in USA. You can set you WAP to 3 distinct channel spaces & not compete or overlap with a neighbor. 1, 6 or 12 give you the widest ranges with fewest chances of overlap. It is something you have to play with on the radio, not the client (RaspPi). They just select the SSID which is set to a channel space.
Joel Huebner
  • 115
To add a note to this query
I have a Raspberry Pi - 2 Model B and I use a LogiLink WiFi adapter on it.
Upon performing iwlist scan I can see all Channels from 1 to 14 (yes! I can scan channel 14)
But if I actually want to use channel 12 or 13 using iwconfig wlan0 channel 12 or iwconfig wlan0 channel 13 I cannot do it initially since the it returns
Error for wireless request "Set Frequency" (8B04) :
SET failed on device wlan0 ; Invalid argument.
Since I am in Europe I can access these channels according to regulations and use them. This got solved according to the following steps
sudo apt-get update
and then did the following
sudo iw reg set *In CAPS your Country Code*
sure enough now iwconfig wlan0 channel 13 will work and the status can be checked using iwconfig wlan0
This might be a bit off topic but this works well since I did not have the problems of not being able to scan channels 12 and 13 but not being able to use it.
I got the information using This Link in German
Note
please check with your Country standardization whether or not you can use the latter channels or not since in some countries these channels are used for other purposes.
Shan-Desai
  • 1,531
My commendations to all. This will get me to a path I'm looking for. AC - tables along with the b-n+ tables. Thank you. When I started wireless networks they were 802.11 1mb protocols. Using an Omni & Uni-directional antenna's I did a lot of 802.11b+ networking. The AC stuff was way too expensive at the time. Compatibility was sparse.
Joel Huebner
  • 115
  • I do not understand what you want to say and how this confused answer help to solve the problem. – Ingo Oct 16 '19 at 08:57
  • 802.11 b-n is what older Pi's with dongle wifi. I believe the ZW, 3A, 3B, 4B all have 802.11 b-n 2.4 GHz and a-c 5 GHz That might be much clearer. Oh yes I was tired with that post. oops. – Joel Huebner Jun 17 '20 at 03:21
