I was wondering whether it was technically possible to install wireless connections for WiFi and Bluetooth (f.ex on a raspberry pi 3) before burning the image to the micro SD card. So you would manipulate the (raspbian) image before you insert the SD card into your Pi.
Asked
Active
Viewed 1,768 times
I know it's possible for Wi-Fi. You need to mount the SD card and edit /etc/network/interfaces.
You should edit the file to look something like this:
auto lo
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug wlan0
auto wlan0 iface
wlan0 inet dhcp
wpa-ssid "SSID"
wpa-psk "password"
Fill in your SSID and password (keep the quotes!)
Greenonline
- 2,740
- 4
- 23
- 36
Wessel
- 21
- 3
Thank you for the response. But I was actually wondering whether I could edit before mounting (so I can burn multiple SD cards for multiple pi's without needing a screen or a lan cable to connect them to the network. – Grégoire Coppens Mar 01 '16 at 19:38
Or did I misunderstood what you meant with "mount the SD-card"? – Grégoire Coppens Mar 01 '16 at 19:43
I mean you need to mount the SD on your laptop/pc. Then edit the interface file, unmount and put in in your Rpi. – Wessel Mar 01 '16 at 20:15
You can also create an image of the modified SD card and burn multiple SD cards. – Wessel Mar 01 '16 at 20:20
If you are going to try this do not use the obsolete settings above, which will break GUI networking and will not automatically restart WiFi. See http://raspberrypi.stackexchange.com/a/37921/8697 for settings. – Milliways Mar 02 '16 at 00:31
