I'm trying to set up my RPi with on-board sound out and a USB mic in, but everything I've found only deals with both audio i/o on the same (external) sound card. What's happening in my situation is that regardless of the default sound card I set, either one of aplay or arecord will fail with an error message that looks like: arecord: main:682: audio open error: No such file or directory (replace arecord with aplay if the default card is set to usb mic).
I know you can add the device name when running the command (arecord -Dhw:1,0 test.wav works, but arecord test.wav doesn't), but I would like that to not happen because I'm using a bunch of pre-compiled libraries that seem to only consider the default devices
EDIT:
For example, I have the following scenario:
in /etc/modprobe.d/alsa-base.conf, commenting out options snd-usb-audio index=-2 will allow arecord to work, but not aplay, and uncommenting the above line will allow aplay to work, but not arecord
ALSA lib pcm_dmix.c:1022:(snd_pcm_dmix_open) unable to open slaveand after a few hours, I ended up here. Great fix, thx. – zipzit Dec 28 '16 at 21:48
