I have a small python script that uses Requests and simply does a GET request from an api to pull data. This script works fine on my computer and fine on a pi A, but not on the actual Pi B that I'm trying use it with.
Basically the script fails to execute the GET request on some URLS, not all, just some....using tail -f /var/log/syslog I can see that this keeps happening:
Feb 22 17:57:55 raspberrypi dhcpcd[445]: eth0: fe80::3e7a:8aff:fe59:68d6 is unreachable, expiring it
Feb 22 17:58:12 raspberrypi dhcpcd[445]: eth0: fe80::3e7a:8aff:fe59:68d6 is unreachable, expiring it
Feb 22 17:58:44 raspberrypi dhcpcd[445]: eth0: fe80::3e7a:8aff:fe59:68d6 is unreachable, expiring it
Feb 22 17:59:01 raspberrypi dhcpcd[445]: eth0: fe80::3e7a:8aff:fe59:68d6 is unreachable, expiring it
Feb 22 17:59:16 raspberrypi dhcpcd[445]: eth0: fe80::3e7a:8aff:fe59:68d6 is unreachable, expiring it
Feb 22 17:59:32 raspberrypi dhcpcd[445]: eth0: fe80::3e7a:8aff:fe59:68d6 is unreachable, expiring it
Feb 22 18:33:12 raspberrypi rsyslogd-2007: action 'action 17' suspended, next retry is Mon Feb 22 18:34:42 2016 [try http://www.rsyslog.com/e/2007 ]
my ifconfig settings:
eth0 Link encap:Ethernet HWaddr bb:bb:bb:bb:bb:bb
inet addr:10.0.0.21 Bcast:10.0.0.255 Mask:255.255.255.0
inet6 addr: bbbb::bbbb:bbbb:bbbb:bbbb/64 Scope:Link
inet6 addr: bbbb:bbb:bbbb:bbbb:bbbb:bbbb:bbbb:bbbb/64 Scope:Global
RX packets:13803 errors:0 dropped:0 overruns:0 frame:0
TX packets:11236 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:2410136 (2.2 MiB) TX bytes:4368966 (4.1 MiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:47 errors:0 dropped:0 overruns:0 frame:0
TX packets:47 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:6156 (6.0 KiB) TX bytes:6156 (6.0 KiB)
Here is my /etc/network/interfaces:
auto lo eth0
iface lo inet loopback
iface eth0 inet static
address 10.0.0.21
netmask 255.255.255.0
gateway 10.0.0.1
I took off real mac address and ipv6 addresses (yes the 2nd eth0 IPV6address looks malformed, but that's what it looked like on my settings)
Also, its not that nothing works - its that certain GET requests don't work...any ideas???
