I have a Raspberry Pi 2 and a LCD
I have no problem with LCD but i want to switch HDMI for video output . i tried to add these line to config.txt :
hdmi_force_hotplug=1
hdmi_drive=2
display_default_lcd=0
but i can't use HDMI even by those codes
anyone have idea? i used raspberry pi about two years ago and i can't remember how to fix this
Update: I used this question before
/boot/config.txtfile? If so, it should work with only the following changes:hdmi_force_hotplug=1use HDMI mode even if no HDMI monitor is detectedhdmi_drive=2set to normal HDMI mode (with sound if supported and enabled) If your HDMI monitor doesn't support sound, try settinghdmi_drive=1since it's possible that the RPi's protocol communications over HDMI with your monitor are determining that sound is not supported and the RPi is disabling the HDMI output. – BartmanEH Feb 07 '16 at 21:50
