I had seen a post in which it was taught how to create your own hosting/server on your computer (but the problem is... You got to keep it running all the time.. It shuts down and the website is down). So I was thinking that considering the money factor Pi can be a great server. P.S. : Not much knowledge about server and all. But still I did understand the working at a very amateur level.
Asked
Active
Viewed 351 times
related: http://raspberrypi.stackexchange.com/questions/325/is-the-raspberry-pi-suitable-for-running-continuously-24-7 – Ghanima Feb 05 '16 at 09:20
You can run sudo apt-get install apache2
on your pi to install Apache2 Webserver. This will install to /var/www
by default where you can change the files. The web server will automatically start on boot. Also, if running this on a home network, you'll need to portforward your router. For more information and how to install apache2, check out this link. Also, start the webserver with sudo service apache2 start
, stop the webserver with sudo service apache2 stop
, and restart the webserver with sudo service apache2 restart
jeffresc
- 199
- 4
