I bought a Hama 00053224 Keypad and I want to use it with my raspberry pi to easily enter digits. Is there a way to install or configure a driver for it on raspbian jessie?
Because nothing happens if I just plug it in. If I try it on my mac book, it works fine without configuration.
lsusb output (I have a Canon printer connected too):
Bus 001 Device 004: ID 04a9:1772 Canon, Inc.
Bus 001 Device 008: ID 05a4:8003 Ortek Technology, Inc.
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Its Bus 001 Device 008: ID 05a4:8003 Ortek Technology, Inc.
I also tried capturing input with python-evdev. I can see the keypad:
>>> from evdev import InputDevice, list_devices
>>> devices = [InputDevice(fn) for fn in list_devices()]
>>> for dev in devices:
... print(dev.fn, dev.name, dev.phys)
('/dev/input/event1', 'Keypad USB Keypad ', 'usb-3f980000.usb-1.5/input1')
('/dev/input/event0', 'Keypad USB Keypad ', 'usb-3f980000.usb-1.5/input0')
But nothing happens if I try to capture the input.
EDIT
I'm pretty sure it has to do with numlock. Because I can see the same stuff as Peter here https://unix.stackexchange.com/questions/123527/targus-usb-number-pad-not-working-in-debian-wheezy But I don't know how to change numlock setting. I tried uncommenting LEDS=+num in /etc/kbd/config but it does not work either.
EDIT II
I also tried with setleds (I'm pts over ssh):
pi@raspberrypi:~ $ who
pi tty1 Jan 31 10:40
pi pts/0 Jan 31 10:42 (192.168.88.214)
pi@raspberrypi:~ $ sudo setleds -D +num < /dev/tty1
pi@raspberrypi:~ $ sudo setleds -D -num < /dev/tty1
But it does not work either :(
EDIT III
Tried with another keyboard with numblock on it. Uncommenting LEDS=+num in /etc/kbd/config works. It just doesn't have any effect on my usb keypad. But it's necessary to get the numbock working after boot.
dmesg output is btw:
[ 4.319902] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.319928] usb 1-1.5: Product: USB Keypad
[ 4.319937] usb 1-1.5: Manufacturer: Keypad
[ 4.326725] input: Keypad USB Keypad as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.0/0003:05A4:8003.0004/input/input2
[ 4.373508] hid-generic 0003:05A4:8003.0004: input,hidraw3: USB HID v1.10 Keyboard [Keypad USB Keypad ] on usb-3f980000.usb-1.5/input0
[ 4.381664] input: Keypad USB Keypad as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.1/0003:05A4:8003.0005/input/input3
[ 4.433868] hid-generic 0003:05A4:8003.0005: input,hidraw4: USB HID v1.10 Mouse [Keypad USB Keypad ] on usb-3f980000.usb-1.5/input1
