So, I've ran arp -a in raspberry pi and it shows some addresses:
? (10.50.220.1) at 00:14:a9:d0:72:80 [ether] on wlan0
? (10.50.221.198) at 48:5a:b6:6d:07:ef [ether] on wlan0
? (10.42.0.1) at 5c:f9:dd:3f:f9:27 [ether] on eth0
? (10.50.220.250) at 70:18:8b:0e:a2:71 [ether] on wlan0
If I try to ping any of those addresses, it works. If I try to ssh, it fails. Also, I tried ifconfig wlan0, which returns a ip address that doesn't exist:
wlan0 Link encap:Ethernet HWaddr 74:da:38:5c:7b:01
inet addr:10.50.221.13 Bcast:10.50.223.255 Mask:255.255.252.0
inet6 addr: fe80::76da:38ff:fe5c:7b01/64 Scope:Link
RX packets:3319 errors:0 dropped:1 overruns:0 frame:0
TX packets:710 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:373186 (364.4 KiB) TX bytes:79057 (77.2 KiB)
When I try to ping ip address 10.50.221.13 from another terminal it fails:
PING 10.50.221.13 (10.50.221.13) 56(84) bytes of data.
From 10.50.221.249 icmp_seq=1 Destination Host Unreachable
From 10.50.221.249 icmp_seq=2 Destination Host Unreachable
From 10.50.221.249 icmp_seq=3 Destination Host Unreachable
From 10.50.221.249 icmp_seq=4 Destination Host Unreachable
From 10.50.221.249 icmp_seq=5 Destination Host Unreachable
From 10.50.221.249 icmp_seq=6 Destination Host Unreachable
^C
--- 10.50.221.13 ping statistics ---
7 packets transmitted, 0 received, +6 errors, 100% packet loss, time 6029ms
pipe 3
Here is the output of /etc/network/interfaces:
interfaces(5) file used by ifup(8) and ifdown(8)
auto lo
iface lo inet loopback
iface eth0 inet dhcp
# The wifi (wireless) network interface
auto wlan0
allow-hotplug wlan0
iface wlan0 inet dhcp
wpa-ssid "optix"
wpa-psk "XXXX"
When I use the app Fing on my phone, it doesn't show that ip address either.
The Raspberry Pi has a Edimax N150 Wi-Fi Nano USB Adapter on it. I only have managed to connect via an ethernet cable.
This may not be the same as other questions, as far as I can tell.
/etc/network/interfaces– Milliways Jan 10 '16 at 05:08interfacesfile - it may work, but doesn't look like any other. See http://raspberrypi.stackexchange.com/a/37921/8697 and restore your files to standard settings. Thearpoutput is pretty meaningless without knowledge of your network architecture. – Milliways Jan 10 '16 at 06:20wpa_supplicant.conffile and, as it isn't your own network, remember to hide any sensitive passwords/keys...! – SlySven Jan 10 '16 at 12:12
