I have a USB Wi-Pi stick which is supposed to enable my Pi to connect to WiFi. I have opened up 'WiFi Configuration' and when trying to connect, the status will show '4-Way Handshake' for about 10 seconds, then scanning and repeats. The IP address is also missing. The Wi-Pi LED flashes throughout.
Here is the /etc/network/interfaces:
auto lo
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug wlan0
iface wlan0 inet dhcp
iface default inet dhcp
And the /etc/wpa_supplicant/wpa_supplicant.conf:
update_config=1
network={
ssid="CORRECT SSID"
psk="CORRECT PASSWORD"
proto=RSN
key_mgmt=WPA-PSK
pairwise=CCMP
auth_alg=OPEN
I have tried looking at many other questions asked here but none have helped. Could it be a problem due to lack of power?
Any help is greatly appreciated and please ask if any other information is required.
wpa_supplicantin the foreground manually; use the commands in parentheses after "If you are using a wifi adapter..." – goldilocks Jan 03 '16 at 18:13/etc/network/interfacesand setting up a static IP address. These made no difference. I then attempted to do what you said to runwpa_supplicantin the foreground. Using thewpa_supplicantcommand gave me a long-ish response about why it failed, let me know if you need to see this. This, as well, made no difference to connecting to wifi. – Mahclark Jan 03 '16 at 22:22ioctl[SIOCSIWENCODEEXT]: Invalid argument ioctl[SIOCSIWENCODEEXT]: Invalid argument ctrl_iface exists and seems to be in use - cannot override it Delete '/var/run/wpa_supplicant/wlan0' manually if it is not used anymore Failed to initialize control interface ‘DIR=/var/run/wpa_supplicant GROUP=netdev’. You may have another wpa_supplicant process already running or the file was left by an unclean termination of wpa_supplicant in which case you will need to manually remove this file before starting wpa_supplicant again.– Mahclark Jan 03 '16 at 22:56wpa_supplicantwhen it is already running. That means you did not disable the network autoconfiguration and reboot as described in that other post (the point of which is not to solve the problem, it is to gather information to help solve the problem). If you can't manage to do that, then you are stuck. You could trysudo killall wpa_supplicantfirst. This will help if the one that's running was started manually by you. Otherwise, if it is because you did not disable the autoconfig, something will just restart it again. – goldilocks Jan 04 '16 at 13:04/etc/network/interfaces-- nothing else. The point is to stop the system from trying to manage the wifi interface by removing it from that list. – goldilocks Jan 04 '16 at 14:16
