i have rpi with jessie release, i can ssh to it through ethernet as i have forced static ip, but i cant ssh to it through wifi. Wifi conection is configured (ssid and psk) and rpi is connected to it. When i execute in my PC command:
nmap -sP 192.168.1.1/24
it finds all devices connected to wifi except raspberry.
I have tryed to force static IP with wifi connection in etc/network/interfaces but then i get no wireless interfaces were found
i have raspberry connected to tv but no keyboard or mouse are available
etc/network/interfaces:
auto lo
iface lo inet loopback
auto eth0
allow-hotplug eth0
#iface eth0 inet manual
iface eth0 inet static
address 192.168.1.188
netmask 255.255.255.0
network 192.168.1.0
broadcast 192.168.1.255
gateway 192.168.1.254
auto wlan0
allow-hotplug wlan0
iface wlan0 inet manual
auto wlan1
allow-hotplug wlan1
iface wlan1 inet manual
result of lsusb:
Bus 001 Device 004: ID 0a5c:bd1e Broadcom Corp.
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub`
etc/wpa_supplicant/wpa_supplicant.conf:
update_config=1
network={
ssid="test-network"
psk="testpasswd"
ifconfig:
eth0 Link encap:Ethernet HWaddr b8:27:eb:66:da:a2
inet addr:192.168.1.188 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::ba27:ebff:fe66:daa2/64 Scope:Link
RX packets:583 errors:0 dropped:0 overruns:0 frame:0
TX packets:422 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:53261 (52.0 KiB) TX bytes:47466 (46.3 KiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:243 errors:0 dropped:0 overruns:0 frame:0
TX packets:243 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:21778 (21.2 KiB) TX bytes:21778 (21.2 KiB)
wlan0 Link encap:Ethernet HWaddr fc:b4:e6:bf:a0:d3
inet addr:192.168.1.58 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::feb4:e6ff:febf:a0d3/64 Scope:Link
RX packets:140 errors:0 dropped:2 overruns:0 frame:0
TX packets:49 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:12631 (12.3 KiB) TX bytes:9147 (8.9 KiB)
Problem got kinda solved, still dont know what caused it but here are attempts to fix and fix:
- checked if wifi is enumerated with
lsusb, it was enumerated. - in
etc/network/interfaceschangediface wlan0 inet manualtoiface wlan0 inet dhcp-> reboot. - with dhcp set
no wireless interfaces were found - tryed
sudo service sshd restartgotdhcpcd not runninginfo when hovered over connection icon - in
/etc/ssh/sshd_configuncommented lineListenAddress 0.0.0.0then reboot and try ssh again, didnt work. - checked wifi dongle on windows 7 and ubuntu 14, worked fine, changed charger to 5V/2A, but still didnt solve anything.
These steps should have solved my problem but they didn't, so i copied to desktop and reverted all changes made to wpa-supplicant and interfaces, connected a touchscreen to rpi andconnected with graphic interface by copyiong psk from wpa-supplicant on desktop. Everything worked fine. I compared working wpa supplicant and interfaces with not-working ones but they where identical, dont know what caused my problem but using graphical interface fixed it.
iface wlan0 inet manualtoiface wlan0 inet dhcpit showsno wireless interfaces found, when its on manual it connects to wifi but cant ssh. – Cynizm Dec 30 '15 at 00:09
