24
So question is: Does all Raspberrys GPIO have a internal pull-up/pull-down resistor which can be enabled from program, in my case Java language with PiJ4?
I have Raspberry Model B+.
yglodt
  • 347
Redex
  • 479
Yes, all of the B+'s GPIO pins have internal pull-up or pull-down resistors that can be controlled from your code.
Pull-up is 50K min – 65K max. Pull-down is 50K min – 60K max.
More info on the GPIO can be found here and here.
Example usage frm the PI4J documentation:
// provision gpio pin #02 as an input pin with its internal pull down resistor enabled
// (configure pin edge to both rising and falling to get notified for HIGH and LOW state
// changes)
GpioPinDigitalInput myButton = gpio.provisionDigitalInputPin(RaspiPin.GPIO_02,             // PIN NUMBER
                                                             "MyButton",                   // PIN FRIENDLY NAME (optional)
                                                             PinPullResistance.PULL_DOWN); // PIN RESISTANCE (optional)
Steve Robillard
  • 34,687
  • 103
  • 109
    To round off your answer it might be worth mentioning that pins 3 and 5 have hard-wired 1k8 pull-ups to 3V3. These pull-ups are needed for the proper operation of the I2C bus. A consequence is that the internal pull-downs have no effect on these pins (the internal pull-downs are much weaker than the external pull-ups). – joan Dec 12 '15 at 14:43
  • @Ghanima Is this the datasheet for Model B+? https://www.raspberrypi.org/documentation/hardware/raspberrypi/bcm2835/BCM2835-ARM-Peripherals.pdf – Redex Dec 15 '15 at 10:37
  • @redex, this is the datasheet for the Broadcom SOC chip used in the B+, the "reduced" schematics of the full board are here. For the internal workings of the BCM your link is for sure worth a visit (it's quite exhaustive, and well, 200 pages long). – Ghanima Dec 15 '15 at 11:32
