I've seen articles describing how to disable LAN on the RPi 1 Model B. But it's not working on my RPi 2 Model B. According to Disable LAN9512 the command is supposed to be:
echo 0x0 > /sys/devices/platform/bcm2708_usb/buspower to disable it, but that doesn't work on my device as I don't have the bcm2708_usb part.
Here is an output of ls -l /sys/devices/platform/
pi@raspberrypi /sys/devices/platform $ ls -l
total 0
drwxr-xr-x  2 root root    0 Dec 10 02:08 alarmtimer
drwxr-xr-x  2 root root    0 Dec 10 02:08 bcm2835_AUD0.0
drwxr-xr-x  2 root root    0 Dec 10 02:08 bcm2835_AUD1.1
drwxr-xr-x  2 root root    0 Dec 10 02:08 bcm2835_AUD2.2
drwxr-xr-x  2 root root    0 Dec 10 02:08 bcm2835_AUD3.3
drwxr-xr-x  2 root root    0 Dec 10 02:08 bcm2835_AUD4.4
drwxr-xr-x  2 root root    0 Dec 10 02:08 bcm2835_AUD5.5
drwxr-xr-x  2 root root    0 Dec 10 02:08 bcm2835_AUD6.6
drwxr-xr-x  2 root root    0 Dec 10 02:08 bcm2835_AUD7.7
drwxr-xr-x  9 root root    0 Dec 10 02:08 clocks
drwxr-xr-x  2 root root    0 Dec 10 02:08 serial8250
drwxr-xr-x 16 root root    0 Dec 10 02:05 soc
drwxr-xr-x  2 root root    0 Dec 10 02:08 timer
-rw-r--r--  1 root root 4096 Dec 10 02:05 uevent
I'm looking for a solution to disable the LAN because my aim is to turn off the chip that provides power to the LAN as I would like to run a test to utilise the cpu only and measure its power consumption.
ACG
    What are you trying to gain by doing this? – Steve Robillard Dec 09 '15 at 23:32
    Need to be more specific. Note that the LAN9512 not only handles LAN but also USB. So while your title says to disable the whole chip (aka including USB) the text suggests that only the LAN should be disabled. (Adding to the obious why?). – Ghanima Dec 09 '15 at 23:45
  • Thanks for the response. My aim is to turn off the chip that provides power to the LAN as I would like to run a test to utilise the cpu only and measure its power consumption. If turning off the LAN wud also turn off the USB, then so be it. But i need to turn it off. I note that there is a simple solution for older RPis (http://raspberrypi.stackexchange.com/questions/8498/disable-lan9512) but the path seems different in RPi 2. – ACG Dec 10 '15 at 02:35
  • @ACG can you post the output of ls -l /sys/devices/platform/ then? I do have /sys/devices/platform/bcm2708_usb/buspower on my Pi 2. But I just executed echo 0x0 > /sys/devices/platform/bcm2708_usb/buspower and got an error. If you do too, then please add that info too to your question. – Diederik de Haas Dec 10 '15 at 03:08
  • @DiederikdeHaas. I've posted the output put its not formatted to be easily read. – ACG Dec 10 '15 at 03:52
  • My instructions were incorrect as it doesn't seem to support triple backticks (backtick = left of 1 on my keyboard; not apostrophes), but I've now fixed it. – Diederik de Haas Dec 10 '15 at 03:54
    @DiederikdeHaas If you are going to post formatting instructions you should read http://raspberrypi.stackexchange.com/editing-help – Milliways Dec 10 '15 at 04:11
  • Thanks for the pointer :-) Didn't realize that 3 backticks is (apparently) GitHub's extension. – Diederik de Haas Dec 10 '15 at 04:14
  • Its only one needed (or a
    tag pair) - but on some systems/keyboard configuration getting a back tick means pressing the key twice (git hub really stresses the key below my ESC one!)
    – SlySven Dec 22 '15 at 00:55
0 Answers0
