I am trying to get my Raspberry Pi to read some audio input through a basic USB souncard and play it back in real time for 10 seconds, and then print the output with Matplotlib after it's finished. I am using PyAudio in callback mode. Audio recording and playback works fine in Audacity.
import pyaudio
import time
import numpy as np
from matplotlib import pyplot as plt
import scipy.signal as signal
CHANNELS = 1
RATE = 44100
p = pyaudio.PyAudio()
fulldata = np.array([])
dry_data = np.array([])
def main():
stream = p.open(format=pyaudio.paFloat32,
channels=CHANNELS,
rate=RATE,
output=True,
input=True,
stream_callback=callback)
stream.start_stream()
while stream.is_active():
time.sleep(10)
stream.stop_stream()
stream.close()
numpydata = np.hstack(fulldata)
plt.plot(numpydata)
plt.title("Wet")
plt.show()
numpydata = np.hstack(dry_data)
plt.plot(numpydata)
plt.title("Dry")
plt.show()
p.terminate()
def callback(in_data, frame_count, time_info, flag):
global b,a,fulldata,dry_data,frames
audio_data = np.fromstring(in_data, dtype=np.float32)
dry_data = np.append(dry_data,audio_data)
#do processing here
fulldata = np.append(fulldata,audio_data)
return (audio_data, pyaudio.paContinue)
main()
After I run my code I can see the the plotted output signal, but it only has very few samples. I can't hear anything through the speakers either while I'm playing. Running the same code on my Windows machine works fine, using the same Python and PyAudio versions.
I have set my USB audio card as default in etc/modprobe.d/alsa-base.conf.
Any help would be much appreciated !
