I have a RPi project where I want to build but alas I'm a programmer, not an electrical engineer. I can solder things, but I couldn't tell you what resistor I needed to put where.
Anyway, I looked around and there's lots of led strips, but I need 25-30 separated leds that are individually addressable for my project.
I looked a lot but found nothing, I figured if anybody would know, it would be you guys.
Ghanima
  • 15,855
  • 119
stu
  • 153
In addition to @joan's answer see: Powering and controlling hundreds of LEDs with a Raspberry pi
Especially if an off-the-shelf solution is wanted, this might be worth a look: individually addressable LED strips, e.g. based on the LPD8806 (example) that seems to have a Pi library.
Ghanima
  • 15,855
  • 119
NeoPixels worked well for me: NeoPixels on Raspberry Pi
Very programmer friendly. I got everything up and running with no soldering, and the python library is very easy to use.
Separated leds, like these?
russau
  • 131
  • hmmm... neat stuff, though you pay what you get for. ~$1.00 an led seems kinda steep, though I don't need many of them. I ordered all the other stuff (the mcp23017) so if I can't muster the brains to make that work, I'll try this. Thanks. – stu Nov 29 '15 at 20:11
  • you can find people selling WS2811/2812 LEDs on alibaba. for me the attraction was a ease of the API. – russau Nov 30 '15 at 01:17
You can buy a couple of MCP23017 port expanders and connect them to the Pi's I2C bus (GPIO 2/3, pins 3/5).
Each MCP23017 has 16 GPIO so that gives you 32 outputs to which you can connect LEDs. You can connect up to 8 MCP23017 to the I2C bus.
joan
  • 71,024
  • 73
  • 106
  • I'll give this a go. Still not sure how to wire it without burning something out but I found a tutorial that seems to do what I'm trying to do... http://www.raspberrypi-spy.co.uk/2013/07/how-to-use-a-mcp23017-i2c-port-expander-with-the-raspberry-pi-part-1/#prettyPhoto – stu Nov 28 '15 at 15:54
