I have Raspbian Jessie on RPI 2 B, I cannot set my wired NIC with a static IP address.
I have uninstalled raspberrypi-net-mods ifplugd, because have a lot of stability issues and insists on uses dhcpcd.....
Now it works fine, but it uses isc-dhcp-client , and I don't want it.
My configuration
root@raspberrypi:~# egrep -v "#|^$" /etc/network/interfaces
auto lo
iface lo inet loopback
allow-hotplug eth0
iface eth0 inet static
address 192.168.80.148
netmask 255.255.255.0
gateway 192.168.80.1
dns-nameservers 192.168.80.1
Logs show as follows:
Nov 26 18:04:58 raspberrypi systemd[30657]: Starting Default.
Nov 26 18:04:58 raspberrypi systemd[30657]: Reached target Default.
Nov 26 18:04:58 raspberrypi systemd[30657]: Startup finished in 37ms.
Nov 26 18:04:58 raspberrypi systemd[1]: Started User Manager for UID 0.
Nov 26 18:05:01 raspberrypi CRON[30683]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 26 18:07:51 raspberrypi dhclient: DHCPREQUEST on eth0 to 192.168.80.1 port 67
Nov 26 18:07:51 raspberrypi dhclient: DHCPACK from 192.168.80.1
Nov 26 18:07:51 raspberrypi systemd[1]: Reloading LSB: start Samba SMB/CIFS daemon (smbd).
Nov 26 18:07:51 raspberrypi smbd[30752]: Reloading /etc/samba/smb.conf: smbd.
Nov 26 18:07:51 raspberrypi systemd[1]: Reloaded LSB: start Samba SMB/CIFS daemon (smbd).
Note I've tried auto instead allow-hotplug but if I reboot router which RPI is plugged it lost its link and I have to poweroff in a dirty way... And logs showing that it is using DHCP:
Any ideas?
192.168.80.XXX
(model of router may help as well). Also I think DNS needs to be set in/etc/resolv.conf
– Wilf Nov 26 '15 at 22:21systemd
or one of its stable-mates could be influencing? – SlySven Nov 27 '15 at 02:31ip addr add
instead ofdhclient
, seeman ip-address
and the certainly many online examples, including at our our larger sibling site Unix & Linux. If you get that to work you can add your own answer. – goldilocks Nov 27 '15 at 18:46
