I'm going to try and order a Pi Zero or two (when they are back in stock...), but whilst waiting I would like to design stuff (basic lasercut case etc) so I can use them effectively.
So does anyone know where I can find drawings (both mechanical (example) and electrical (example)) of it? (Also compatibility with previous versions and whether the SoC is equiavlent to a overclocked version of the one on the Pi 1)
What I do know (from here):
  • A Broadcom BCM2835 application processor
  • 1GHz ARM11 core (40% faster than Raspberry Pi 1)
  • 512MB of LPDDR2 SDRAM
  • A micro-SD card slot
  • A mini-HDMI socket for 1080p60 video output
  • Micro-USB sockets for data and power
  • An unpopulated 40-pin GPIO header
  • Identical pinout to Model A+/B+/2B
  • An unpopulated composite video header
Our smallest ever form factor, at 65mm x 30mm x 5mm
Glorfindel
  • 620
Wilf
  • 2,513
  • 38
Given that not even the schematics of the Pi2 are released I doubt that we will see the electrical design any time soon. (And there might of course be valid concerns at the Foundation to not release them.)
However the mechanical drawings are available at raspberrpi.org in the section documentation > hardware > raspberrypi > mechanical.
Glorfindel
  • 620
Ghanima
  • 15,855
  • 119
  • LOL I'm unobservant (or they added it afterwards...). Thanks! – Wilf Nov 26 '15 at 20:16
    I was going with "they added it afterwards" ^^ – Ghanima Nov 26 '15 at 20:19
  • Quick correction: the Raspberry Pi2 schematic is available at https://www.raspberrypi.org/wp-content/uploads/2012/10/Raspberry-Pi-R2.0-Schematics-Issue2.2_027.pdf – oskarpearson Nov 27 '15 at 17:14
    @oskarpearson, no, unfortunately not. It's the Revision 2.0 of the Pi 1. Same as is listed in the help > documentation > hardware > raspberrypi > schematics section on raspberrypi.org – Ghanima Nov 27 '15 at 18:07
To add to Ghanima's answer:
It is the exact same chip that's in the RPi 1, just clocked faster. The foundation mentions that in a video on the product's announcement page. Look at about 1:15 mark.
Jacobm001
  • 11,898
  • 46
  • 56
