Occasionally, when I power up my friendly RPi, the screen stays blank as if there is no output from the HDMI. I can still ssh to the device, so it is working.
Can anyone suggest reasons why it may be happening and how to fix it?
This was due to incorrect settings in /boot/config.txt.
Actually deleting the config file solved my issue, but its purpose and possible parameters are documented here.
The contents of my file were:
hdmi_mode=19
#arm_freq=800
disable_overscan=1
This is what comes by default in Arch. The hdmi_mode=19 setting sets the HDMI output to 1024x768 85Hz, which is apparently an unsupported resolution for my monitor.
I believe that deleting the file sets the output to hdmi_mode=1, which is VGA. Clearly this is suboptimal, so I recommend experimenting to find the best value.
Another possibility I came across is that I didn't get any display unless the HDMI cable was plugged in before the Pi was switched on.
Should be a relatively quick one to fault-find, but worth documenting here nonetheless.
hdmi_force_hotplug=1 option as documented on http://elinux.org/RPiconfig?
– Lekensteyn
May 13 '13 at 21:40
