I just made a clean install of Raspbian Jessie, and my WiFi adapter doesn't seem to work. It was working on wheezy.
> lsusb
Bus 001 Device 004: ID 148f:7601 Ralink Technology, Corp.
I did have the firmware /lib/firmware/mt7601u.bin
by default
> iwconfig
wlan0 IEEE 802.11bgn ESSID:off/any
Mode:Managed Access Point: Not-Associated Tx-Power=20 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Power Management:off
/etc/network/interfaces
auto lo
iface lo inet loopback
iface eth0 inet manual
auto wlan0
allow-hotplug wlan0
iface wlan0 inet manual
allow-hotplug wlan1
iface wlan1 inet manual
I have added the SSID and password in /etc/wpa_supplicant/wpa_supplicant.conf
Can someone help me with this?
EDIT:
On running
sudo ifup wlan0
I get this error:
wpa_supplicant: /sbin/wpa_supplicant daemon failed to start
run-parts: /etc/network/if-pre-up.d/wpasupplicant exited with return code 1
Failed to bring up wlan0.
dhcp
will disabledhcpcd
and prevent the WiFi widget in GUI from running. You are of course welcome to setup your Pi in any way, but it would be better to get the standard setup working. Your initial question looked like it should work, check any boot messages (or look atdmesg
for hints. You may be interested in checking the setup in:- http://raspberrypi.stackexchange.com/questions/37920/how-do-i-set-up-networking-wifi-static-ip/37921#37921 – Milliways Nov 22 '15 at 22:24dmesg doesnt show any specific errors except
– tejas Nov 23 '15 at 15:51[ 15.558404] bcm2708_fb soc:fb: Unknown ioctl 0x40187a22
