I'm using Raspbian in a Raspberry Pi 2 Model B
I've followed the guidelines in the RStudio Webpage and also in this topic https://www.raspberrypi.org/forums/viewtopic.php?f=34&t=55828
sudo su
apt-get install git r-recommended
git clone https://github.com/rstudio/rstudio.git
cd rstudio
./dependencies/linux/install-dependencies-debian
mkdir build
cd build
cmake .. -DRSTUDIO_TARGET=Server -DCMAKE_BUILD_TYPE=Release
make install
But when doing cmake .. -DRSTUDIO_TARGET=Server -DCMAKE_BUILD_TYPE=Release it throws me this error:
CMake Error at src/cpp/session/CMakeLists.txt:23 (message):
Dictionaries not found (re-run install-dependencies script to install)
-- Configuring incomplete, errors occurred!
See also "/home/pi/rstudio/build/CMakeFiles/CMakeOutput.log".
See also "/home/pi/rstudio/build/CMakeFiles/CMakeError.log".
I've tried reinstalling dependencies but that didn't help
This is the Error log:
Determining if the function getpeereid exists failed with the following output:
Change Dir: /home/pi/rstudio/build/CMakeFiles/CMakeTmp
Run Build Command:"/usr/bin/make" "cmTryCompileExec3944045131/fast"
/usr/bin/make -f CMakeFiles/cmTryCompileExec3944045131.dir/build.make CMakeFiles/cmTryCompileExec3944045131.dir/build
make[1]: Entering directory '/home/pi/rstudio/build/CMakeFiles/CMakeTmp'
/usr/bin/cmake -E cmake_progress_report /home/pi/rstudio/build/CMakeFiles/CMakeTmp/CMakeFiles 1
Building C object CMakeFiles/cmTryCompileExec3944045131.dir/CheckFunctionExists.c.o
/usr/bin/cc -DCHECK_FUNCTION_EXISTS=getpeereid -o CMakeFiles/cmTryCompileExec3944045131.dir/CheckFunctionExists.c.o -c /usr/share/cmake-3.0/Modules/CheckFunction$
Linking C executable cmTryCompileExec3944045131
/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTryCompileExec3944045131.dir/link.txt --verbose=1
/usr/bin/cc -DCHECK_FUNCTION_EXISTS=getpeereid CMakeFiles/cmTryCompileExec3944045131.dir/CheckFunctionExists.c.o -o cmTryCompileExec3944045131 -rdynamic
CMakeFiles/cmTryCompileExec3944045131.dir/CheckFunctionExists.c.o: In function `main':
CheckFunctionExists.c:(.text+0x14): undefined reference to `getpeereid'
collect2: error: ld returned 1 exit status
CMakeFiles/cmTryCompileExec3944045131.dir/build.make:88: recipe for target 'cmTryCompileExec3944045131' failed
make[1]: *** [cmTryCompileExec3944045131] Error 1
make[1]: Leaving directory '/home/pi/rstudio/build/CMakeFiles/CMakeTmp'
Makefile:118: recipe for target 'cmTryCompileExec3944045131/fast' failed
make: *** [cmTryCompileExec3944045131/fast] Error 2
Do you know what could be happening?
EDIT 1:
This is the output of running ./dependencies/linux/install-dependencies-debian:
root@raspberrypi:/home/pi/rstudio# ./dependencies/linux/install-dependencies-debian
Reading package lists... Done
Building dependency tree
build-essential is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
pkg-config is already the newest version.
fakeroot is already the newest version.
cmake is already the newest version.
uuid-dev is already the newest version.
libssl-dev is already the newest version.
libbz2-dev is already the newest version.
zlib1g-dev is already the newest version.
Note, selecting 'libpam0g-dev' instead of 'libpam-dev'
libpam0g-dev is already the newest version.
libxslt1-dev is already the newest version.
libapparmor1 is already the newest version.
apparmor-utils is already the newest version.
libboost-all-dev is already the newest version.
libpango1.0-dev is already the newest version.
Package openjdk-6-jdk is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
apt
E: Package 'openjdk-6-jdk' has no installation candidate
It tells me that openjdk-6-jdk is needed but it's not in the repos. I've installed openjdk-7-jdk manually, but installing it didn't work.
After doing that, I commented (#) the line in which tries to install openjdk-6-jdk. Now it follows installing packages and these are (the last lines) of the output:
ant is already the newest version.
unzip is already the newest version.
./dependencies/linux/install-dependencies-debian: line 58: cd: ../common: No such file or directory
I've entered again in the file install-dependencies-linux and these are the lines that fail:
cd ../common
./install-common
cd ../linux
But I don't know what's trying to install. After these lines, begin the lines of installing the Qt but that's for the RStudio Desktop version, not my Server version.
EDIT 2:
I discovered using the command find / -name install-common that there was a common directory under the dependencies directory. So I cd'ed to /dependencies/common/ and manually performed a ./install-common
root@raspberrypi:/home/pi/rstudio/dependencies/common# ./install-common
--2015-11-21 19:26:41-- https://s3.amazonaws.com/rstudio-buildtools/gin-1.5.zip
Resolving s3.amazonaws.com (s3.amazonaws.com)... 54.231.98.155
Connecting to s3.amazonaws.com (s3.amazonaws.com)|54.231.98.155|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 1055663 (1.0M) [application/zip]
Saving to: ‘gin-1.5.zip’
gin-1.5.zip 100%[=====================>] 1.01M 951KB/s in 1.1s
2015-11-21 19:26:43 (951 KB/s) - ‘gin-1.5.zip’ saved [1055663/1055663]
--2015-11-21 19:26:44-- https://s3.amazonaws.com/rstudio-buildtools/gwt-2.7.0.zip
Resolving s3.amazonaws.com (s3.amazonaws.com)... 54.231.9.24
Connecting to s3.amazonaws.com (s3.amazonaws.com)|54.231.9.24|:443... connected.
Length: 108818328 (104M) [application/zip]
Saving to: ‘gwt-2.7.0.zip’
gwt-2.7.0.zip 100%[=====================>] 103.78M 7.80MB/s in 20s
2015-11-21 19:27:04 (5.27 MB/s) - ‘gwt-2.7.0.zip’ saved [108818328/108818328]
--2015-11-21 19:27:36-- https://s3.amazonaws.com/rstudio-buildtools/junit-4.9b3.jar
Resolving s3.amazonaws.com (s3.amazonaws.com)... 54.231.49.132
Connecting to s3.amazonaws.com (s3.amazonaws.com)|54.231.49.132|:443... connected.
Length: 247280 (241K) [application/java-archive]
Saving to: ‘junit-4.9b3.jar’
junit-4.9b3.jar 100%[=====================>] 241.48K 246KB/s in 1.0s
2015-11-21 19:27:38 (246 KB/s) - ‘junit-4.9b3.jar’ saved [247280/247280]
--2015-11-21 19:27:38-- https://s3.amazonaws.com/rstudio-buildtools/selenium-java-2.37.0.zip
Resolving s3.amazonaws.com (s3.amazonaws.com)... 54.231.112.67
Connecting to s3.amazonaws.com (s3.amazonaws.com)|54.231.112.67|:443... connected.
Length: 24625928 (23M) [application/zip]
Saving to: ‘selenium-java-2.37.0.zip’
selenium-java-2.37. 100%[=====================>] 23.48M 2.28MB/s in 16s
2015-11-21 19:27:55 (1.45 MB/s) - ‘selenium-java-2.37.0.zip’ saved [24625928/24625928]
--2015-11-21 19:28:00-- https://s3.amazonaws.com/rstudio-buildtools/selenium-server-standalone-2.37.0.jar
Resolving s3.amazonaws.com (s3.amazonaws.com)... 54.231.114.92
Connecting to s3.amazonaws.com (s3.amazonaws.com)|54.231.114.92|:443... connected.
Length: 34730734 (33M) [application/x-java-archive]
Saving to: ‘selenium-server-standalone-2.37.0.jar’
selenium-server-sta 100%[=====================>] 33.12M 4.39MB/s in 8.6s
2015-11-21 19:28:10 (3.84 MB/s) - ‘selenium-server-standalone-2.37.0.jar’ saved [34730734/34730734]
--2015-11-21 19:28:10-- https://s3.amazonaws.com/rstudio-buildtools/chromedriver-mac
Resolving s3.amazonaws.com (s3.amazonaws.com)... 54.231.96.144
Connecting to s3.amazonaws.com (s3.amazonaws.com)|54.231.96.144|:443... connected.
Length: 22034760 (21M) [application/octet-stream]
Saving to: ‘chromedriver-mac’
chromedriver-mac 100%[=====================>] 21.01M 5.39MB/s in 4.8s
2015-11-21 19:28:15 (4.34 MB/s) - ‘chromedriver-mac’ saved [22034760/22034760]
--2015-11-21 19:28:15-- https://s3.amazonaws.com/rstudio-buildtools/chromedriver-linux
Resolving s3.amazonaws.com (s3.amazonaws.com)... 54.231.97.227
Connecting to s3.amazonaws.com (s3.amazonaws.com)|54.231.97.227|:443... connected.
Length: 19303552 (18M) [application/octet-stream]
Saving to: ‘chromedriver-linux’
chromedriver-linux 100%[=====================>] 18.41M 2.53MB/s in 9.4s
2015-11-21 19:28:25 (1.95 MB/s) - ‘chromedriver-linux’ saved [19303552/19303552]
--2015-11-21 19:28:25-- https://s3.amazonaws.com/rstudio-buildtools/chromedriver-win.exe
Resolving s3.amazonaws.com (s3.amazonaws.com)... 54.231.13.152
Connecting to s3.amazonaws.com (s3.amazonaws.com)|54.231.13.152|:443... connected.
Length: 6731776 (6.4M) [application/octet-stream]
Saving to: ‘chromedriver-win.exe’
chromedriver-win.ex 100%[=====================>] 6.42M 2.52MB/s in 2.6s
2015-11-21 19:28:29 (2.52 MB/s) - ‘chromedriver-win.exe’ saved [6731776/6731776]
--2015-11-21 19:28:29-- https://s3.amazonaws.com/rstudio-dictionaries/core-dictionaries.zip
Resolving s3.amazonaws.com (s3.amazonaws.com)... 54.231.10.192
Connecting to s3.amazonaws.com (s3.amazonaws.com)|54.231.10.192|:443... connected.
Length: 876339 (856K) [application/zip]
Saving to: ‘core-dictionaries.zip’
core-dictionaries.z 100%[=====================>] 855.80K 1.00MB/s in 0.8s
2015-11-21 19:28:31 (1.00 MB/s) - ‘core-dictionaries.zip’ saved [876339/876339]
--2015-11-21 19:28:31-- https://s3.amazonaws.com/rstudio-buildtools/mathjax-23.zip
Resolving s3.amazonaws.com (s3.amazonaws.com)... 54.231.1.152
Connecting to s3.amazonaws.com (s3.amazonaws.com)|54.231.1.152|:443... connected.
Length: 1674748 (1.6M) [application/zip]
Saving to: ‘mathjax-23.zip’
mathjax-23.zip 100%[=====================>] 1.60M 578KB/s in 2.8s
2015-11-21 19:28:35 (578 KB/s) - ‘mathjax-23.zip’ saved [1674748/1674748]
1.50.0 already installed in /opt/rstudio-tools/boost/boost_1_50_0
--2015-11-21 19:28:35-- https://s3.amazonaws.com/rstudio-buildtools/pandoc-1.13.1.zip
Resolving s3.amazonaws.com (s3.amazonaws.com)... 54.231.64.184
Connecting to s3.amazonaws.com (s3.amazonaws.com)|54.231.64.184|:443... connected.
Length: 115697042 (110M) [application/zip]
Saving to: ‘pandoc-1.13.1.zip’
pandoc-1.13.1.zip 100%[=====================>] 110.34M 1.99MB/s in 44s
2015-11-21 19:29:20 (2.52 MB/s) - ‘pandoc-1.13.1.zip’ saved [115697042/115697042]
cp: cannot stat ‘pandoc-1.13.1/linux/debian/armv7l/pandoc*’: No such file or directory
And now when I perform again a cmake this is the output:
root@raspberrypi:/home/pi/rstudio/build# cmake .. -DRSTUDIO_TARGET=Server -DCMAKE_BUILD_TYPE=Release
-- Boost version: 1.50.0
-- Found R: /usr/lib/R
CMake Error at src/cpp/session/CMakeLists.txt:32 (message):
rsconnect package not found (re-run install-dependencies script to install)
At least now it throws an error in a different line!
EDIT 3:
I installed manually the dependencies inside the install-common and now the cmake command works! Yay!
Now I've performed a make install but it gets stuck here:
Buildfile: /home/pi/rstudio/src/gwt/build.xml
ext:
apt-get ...and./dependencies/linux/install-dependencies-debian)? – Wilf Nov 21 '15 at 18:54apt-get ...went all okay.git is already the newest version. r-recommended is already the newest version.– Geiser Nov 21 '15 at 19:24
