I want to use my raspberry pi 2 as an media center and use movies from my usb HDD Now the problem is that it runs short on power for that usb HDD (my usb hdd uses 2 usb ports btw)
Now I found an old usb hub with external power supply (5v, 2A) and I have a small box where I can fit both the usb hub and the Pi in, to keep everything clean I want to make those 2 power cables into 1, this ain't that hard but now the problem:
The hdmi port is on thesame side as the power in port, so my question is can I give power to it without having to access this port? Will this have any cons/pros and how can I do this?
max_usb_current=1, there should be 1200 mA available to the USB ports, and technically, a conforming USB device should not expect more than 500 mA per port. However, officially without it set there should still be 600 mA, which should be enough for one port, but my HDD (which only uses one port) definitely won't work that way, whereas using the same 2.5 A supply with max_current set it does. – goldilocks Oct 28 '15 at 17:42
