21
I have a python script running by cron. For what ever reason, it is not running. I am wondering if there is anywhere that error messages are sent? Script runs fine by itself. If I run a simple script with crontab, that just writes to a file that works also.
My crontab is:
*/15 * * * * python ./home/pi/foo/bar.pyw
Richard
  • 471
    Ok, I figured out the issue with my script. I was calling modules which were in the same directory as the bar.pyw script. I changed the working directory with os.chdir("some location"). I still however would like to know where the error messages go for crontabs – Richard Nov 26 '12 at 19:46
By default, the logging for the cron daemon is not enabled in Debian (I assume it is the system you are using). To enable it, please open the file /etc/rsyslog.conf via
$ vi /etc/rsyslog.conf
and uncomment the line
# cron.*                          /var/log/cron.log
After that, you need to restart rsyslog via
$ /etc/init.d/rsyslog restart
and you will find the cron logs in /var/log/cron.log
Source: Enable crontab logging in Debian Linux
Kioshiki
  • 103
Morgan Courbet
  • 3,703
  • 38
    Alf: Thank you for your reply. I have now implemented cron logging and have alter the command in my crontab to [Code] /3 * * * /usr/bin/sudo -H /home/pi/ahbc [/code] The sudo -H is something I found on the web which I am told works. I don't understand just what the -H is there for. I have been given to understand that if one does not include the uservin a crontab command line that command will run using the user/owner of crontab. Therefore as my crontab is user pi crontab the contained commands will run for pi. – Bex Jan 12 '15 at 07:42
  • the link is broken now :( – Michael Jun 08 '15 at 20:27
  • @Michael The explanation here should be enough to achieve logging. Do you need something else? – Morgan Courbet Jun 08 '15 at 21:43
    @ElanHasson Anything that generates extra writes to the SD card and is a low priority is generally disabled on the rPi. – SiKing Dec 02 '16 at 16:39
  • I've just posted an edit request for the link, it looks like the source site just changed it's setup a bit. – Kioshiki Jan 22 '17 at 14:53
  • If you want to monitor it is real time, use tail -f /syslog – SDsolar Jun 02 '17 at 06:27
Crontab has several parameters (in additional to time execution lines) For example:
MAILTO="you@example.com"
SHELL="/bin/bash"
goldilocks
  • 58,859
  • 112
  • 227
DGerman
  • 41
