15
I am trying to enable monitoring mode for a USB wifi dongle with the RTL8188CUS chipset on a raspberry pi model b+ (or any raspberry pi for that matter).
$ lsusb
Bus 001 Device 005: ID 0bda:8176 Realtek Semiconductor Corp. RTL8188CUS 802.11n WLAN Adapter
$ sudo iwconfig wlan0 mode monitor
Error for wireless request "Set Mode" (8B06) :
    SET failed on device wlan0 ; Invalid argument.
According to github/raspberrypi/linux/issues/369, you need to enable the rtlwifi/rtl8192cu kernel module that is included with the kernel distribution but not compiled. This requires minor modifications to some files as diff'ed below in 'STEP 2'.
The USB issue mentioned in that thread has been resolved as of 4.1.6+, so the rtlwifi driver should work.
Steps to recreate on a fresh raspberry pi (model B+)...
STEP 0: Update existing modules and kernel to latest
$ sudo apt-get update
$ sudo rpi-update
$ uname -a
Linux raspberrypi 4.1.7+ #815 PREEMPT Thu Sep 17 17:59:24 BST 2015 armv6l GNU/Linux
STEP 1: Get the raspbian kernel source and add missing dependencies
$ git clone --depth=1 https://github.com/raspberrypi/linux
$ sudo apt-get install bc lshw
STEP 2: Enable the rtlwifi (kernel) drivers for RTL8188CUS (RTL8192)
edit linux/drivers/net/wireless/Kconfig
-#source "drivers/net/wireless/rtlwifi/Kconfig"
-source "drivers/net/wireless/rtl8192cu/Kconfig"
+source "drivers/net/wireless/rtlwifi/Kconfig"
+#source "drivers/net/wireless/rtl8192cu/Kconfig"
edit linux/drivers/net/wireless/Makefile
-#obj-$(CONFIG_RTLWIFI)         += rtlwifi/
+obj-$(CONFIG_RTLWIFI)          += rtlwifi/
STEP 3: Compile and install kernel (took many hours)
Summarized from kernel building documentation .
$ cd linux
$ KERNEL=kernel
$ make bcmrpi_defconfig
$ make zImage modules dtbs
$ sudo make modules_install
$ sudo cp arch/arm/boot/dts/*.dtb /boot/
$ sudo cp arch/arm/boot/dts/overlays/*.dtb* /boot/overlays/
$ sudo cp arch/arm/boot/dts/overlays/README /boot/overlays/
$ sudo scripts/mkknlimg arch/arm/boot/zImage /boot/$KERNEL.img
STEP 4: Reboot
$ sudo reboot
STEP 5: Check that the rtlwifi/rtl8192cu module is loaded
$ lsmod | fgrep rtl8192cu
rtl8192cu             100806  0
rtl_usb                14781  1 rtl8192cu
rtl8192c_common        72091  1 rtl8192cu
rtlwifi               101122  3 rtl_usb,rtl8192c_common,rtl8192cu
mac80211              623281  3 rtl_usb,rtlwifi,rtl8192cu
$ lshw
  *-network:0
       description: Ethernet interface
       physical id: 1
       bus info: usb@1:1.3
       logical name: wlan0
       serial: 00:0b:81:94:e9:a3
       capabilities: ethernet physical
       configuration: broadcast=yes driver=rtl8192cu driverversion=4.1.7+ firmware=N/A link=no multicast=yes
STEP 6: Try to activate monitoring mode
    SET failed on device wlan0 ; Operation not supported.
What did i miss?
Issue 369 seems to indicate that it can work with the rtlwifi driver?
Matt M
  • 331
  • This, sir, was extremely helpful. I followed the steps pretty much exactly, and it worked like a charm. – Alex Nichol Feb 14 '16 at 23:07
  • With all due respect and bonus points for perseverance, IMHO this is also rather cumbersome. See here, you can get a wifi dongle with a chipset that supports monitor mode out of the box, for under 5 USD including shipping. – RolfBly Jun 11 '17 at 21:05
  • I was wondering if you'd had any luck getting this to work with Raspbian Buster (10)? I've partially completed a tutorial (still have a kernel panic problem) on this using resources fro various places, including here, and would like there to be an up to date resource on this some. My tutorial is at https://www.hamishmb.com/blog/how-to-make-a-raspi-ap-with-a-rtl8xxx-wifi-adaptor/ if you're interested. I'd really appreciate if any of you could let me know if you figured this out at some point or have – Hamish McIntyre-Bhatty Feb 12 '20 at 12:42
Turns out the steps to recompile and load the rtlwifi module are correct. The problem is iwconfig not working to enable/determine monitoring mode in this situation.
Instead, I used iw as outlined by Steven Gordon and it worked.
To summarize:
STEP 6b: List the physical network interfaces available
$ iw dev
STEP 7: Determine if the physical interface supports monitoring mode
$ iw phy phy0 info
... lots of stuff ...
Supported interface modes:
     * IBSS
     * managed
     * AP
     * AP/VLAN
     * monitor
     * mesh point
     * P2P-client
     * P2P-GO
... lots more stuff ...
STEP 8: Add a monitoring interface to that physical card
You need to explicitly add a 'monitoring' interface for the hardware you have.
$ sudo iw phy phy0 interface add mon0 type monitor
STEP 8: Start monitoring
In my case, I'm using tshark to facilitate monitoring, displaying a few useful fields rather than a lot of noise.
$ sudo apt-get install tshark
$ sudo tshark -i mon0 -f 'broadcast' -T fields -e frame.time_epoch -e wlan.sa -e radiotap.dbm_antsignal -e wlan.fc.type -e wlan.fc.subtype
Done.
Matt M
  • 331
  • Your link is broken, you're missing the last few characters: https://sandilands.info/sgordon/capturing-wifi-in-monitor-mode-with-iw (I tried to edit your post but apparently edits must be at least 6 characters...) – Ted Mielczarek Aug 26 '16 at 10:39
  • I don't understand what to do in Step #2 // need help. – Ray Kodiak Sep 16 '16 at 04:17
  • Inside the git repo you cloned in step 1 ('linux' directory)... Edit the file 'linux/drivers/net/wireless/Kconfig', comment out the 2 lines with rtl8192cu in them by adding a '#' to the beginning of the line. Edit the file 'linux/drivers/net/wireless/Makefile', comment out the 1 line with rtl8192cu, uncomment the line with rtlwifi. – Matt M Sep 16 '16 at 18:59
Great instructions. Thank you. Couple of more things I needed to do...
  1. When I rebooted my raspberry pi 3 with the new image (4.9.13-v7+), lsmod did list the rtl8192cu though the rtl8192cu directory was in /lib/modules/4.9.13-v7+/kernel/drivers/net/wireless/realtek/rtlwifi/rtl8192cu Solution: I had to do a sudo modprobe rtl8192cu
  2. iwconfig jsut says "No wireless extensions" even for the interfaces that are actively connected to an AP. I am using iw instead. See instructions in http://linuxwireless.org/en/users/Documentation/iw/__v41.html
