I've been using my raspberry pi through Ethernet connection normally. I am powering it through microUSB via my laptop's USB port. Everything was working normally until I installed a new version of gcc by following this guide. After successfully installing gcc I was using my pi normally until I lost connection with my pi.
I tried removing and re-plugging both the Ethernet and the microUSB connectors but nothing is working. When I power up the pi the ACT light flashes for a few seconds and then only the power led stays on. Usually when I plug my Ethernet cable all the other leds flash.
I plugged the SD card into my laptop and it works normally.
I connected my rpi to the monitor, I am getting the following:
[1.153151] ---[end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown block (179, 2)
[81.6939987]: random: nonblocking pool is initialized
Any help?
