So, I was doing an installation of Raspbian without a monitor or keyboard, as outlined here and I was at the stage where you insert the sd card with some changed configuration files and wait for it to install. However, during this process I have accidentally pressed on the card and it removed from its slot. I put it back in, but now the only light flashing is red, I guess it is the power light. What should I do now? Will I need to somehow reboot the installation?
Update: following recommendations, I have tried powering it off, reinserting the sd card and powering it on again. Still nothing. When I plugged the sd card into my main computer it had 2 partitions, one called BOOT, I guess the installation started before I interrupted it. I have formatted the sd card and put NOOBS on it. After inserting the card back into rpi the green light flashes for a bit and then nothing happens.
user20997
  • 159
  • Have you tried a power cycle? I.e. switch off, insert the SD card, power on. See if the green LED flashes. – joan Aug 25 '15 at 19:55
  • @joan did it now, will see how it goes... – user20997 Aug 25 '15 at 19:56
  • Don't insert or remove the SD card with the power on. There's nothing that can be accomplished that way. As joan says, to boot properly, you need to apply power with a card already inserted. If you insert it after that, nothing will happen. – goldilocks Aug 25 '15 at 19:58
  • the green light flashed for a bit, now it's back to red only. I am doing ping raspberrypi.local and it says "Unknown host". – user20997 Aug 25 '15 at 20:20
Ok, I have sorted it out. I just reformatted the sd card and started a new installation. Worked perfectly.
user20997
  • 159
