I have a eDIO USB Multi Remote Controller( a Infrared Reciever) that came with ASUS PSR 2000 Web Surfing Remote Control.
I am trying to connect the Remote COntroller to my pi so that it recieves the keystrokes sent by the remote.
The controller is detected as a HID device. Here are the details from the lsusb -v command
Bus 001 Device 007: ID 147a:e001 Formosa Industrial Computing, Inc.
Couldn't open device, some information will be missing
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 1.10
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 8
idVendor 0x147a Formosa Industrial Computing, Inc.
idProduct 0xe001
bcdDevice 1.22
iManufacturer 1
iProduct 2
iSerial 0
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 34
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 4
bmAttributes 0xa0
(Bus Powered)
Remote Wakeup
MaxPower 300mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 3 Human Interface Device
bInterfaceSubClass 1 Boot Interface Subclass
bInterfaceProtocol 2 Mouse
iInterface 0
HID Device Descriptor:
bLength 9
bDescriptorType 33
bcdHID 1.10
bCountryCode 0 Not supported
bNumDescriptors 1
bDescriptorType 34 Report
wDescriptorLength 20
Report Descriptors:
** UNAVAILABLE **
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0004 1x 4 bytes
bInterval 10
I can also view the target device in the dev folder with an event created
pi@raspberrypi /dev/input/by-id $ dir
usb-Cypress_Semiconductor_eDio_USB_Multi_Remote_Controlle-event-if00
The event handler associated with it is as follows as seen from the following command.
pi@raspberrypi /proc/bus/input $ cat devices
I: Bus=0003 Vendor=147a Product=e001 Version=0110
N: Name="Cypress Semiconductor eDio USB Multi Remote Controlle"
P: Phys=usb-bcm2708_usb-1.2/input0
S: Sysfs=/devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2:1.0/input/input2
U: Uniq=
H: Handlers=event0
B: PROP=0
B: EV=1
The problem is when I am trying to read the output from the event handler created for the device.The first keystroke is registered but the subsequent key strokes are not displayed by the CAT command.
pi@raspberrypi /dev/input $ cat event0 | xxd
0000000: e007 9450 9476 0900 0000 0000 0000 0000 ...P.v..........
Please suggest me what can I do to get the device working. Pressing any keys after the first keystroke doesn't return anything unless the device is replugged.
Please suggest what needs to be done to fix the issue.
|xxd? It buffers the output. I usedirwfrom packagelircto get the keycodes sent by my remote. – macrojames Nov 05 '12 at 08:23
