12
I am getting an error using espeak. Audio comes out the head phone jack, but all of this stuff get written to the command line. I installed espeak and alsa-utils. Any idea how to fix these errors?
[kevin@raspberrypi ~]$ sudo espeak "hello"
[sudo] password for kevin:
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.front
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround40
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround41
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround50
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround51
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround71
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.iec958
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
ALSA lib pcm_dmix.c:957:(snd_pcm_dmix_open) The dmix plugin supports only playback stream
ALSA lib pcm_direct.c:877:(snd1_pcm_direct_initialize_slave) slave plugin does not support mmap interleaved or mmap noninterleaved access
ALSA lib pcm_dmix.c:1030:(snd_pcm_dmix_open) unable to initialize slave
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
Jivings
  • 22,538
  • 90
  • 139
kevin
  • 1,294
  • 26
Here is the short solution:
sudo espeak "hello" 2>/dev/null
Here is my explanation:
The output you're seeing is normal.
Jack is an audio server and the errors report that Jack is not installed. There's nothing wrong with this, espeak will just use a different audio engine such as ALSA or Pulse. In your case it looks like it's using ALSA.
The above command will just hide the output from you.
Jivings
  • 22,538
  • 90
  • 139
You can get rid of the annoying messages about jack by running the jack server with the following command line:
jackd -r -m -p 8 -d dummy
I put this in my ~/.config/autostart/jackd.desktop
[Desktop Entry]
Type=Application
Name=jackd
Exec=jackd -p 8 -r -m -d dummy > /dev/null 2>&1
StartupNotify=false
RPiAwesomeness
  • 3,001
  • 30
  • 51
user13029
Found the answer for this here:
http://alexpb.com/notes/articles/2012/11/14/error-when-playing-audio-on-raspbian-on-a-raspberry-pi/
in
/usr/share/alsa/alsa.conf
   change the line "pcm.front cards.pcm.front"
             to "pcm.front cards.pcm.default"
worked for me. Can't tell if there is other better solution.
mjk
Turns out pulseaudio ruins ALSA. For me, espeak worked with 'sudo' only. After apt-get --purge remove pulseaudio, things got back to normal.
Chris
