I have one of the newer Raspberry Pi 2 B, and wish to install Pidora. I have downloaded Pidora-2014-R3 (the [latest?] version available from the front page of the Pidora site) and copied it on to a microSD card, and inserted it into the microSD slot on the RPi. When I power up the Pi, the green ACT LED lights momentarily, but then goes out and the RPi does not boot.
I have followed the installation instructions from Pidora as well as the two guides from Raspberry Pi Documentation: Installing Operating System Images on Mac OS - and Installing Operating System Images using Windows. I have tried both copying Pidora on to the microSD cad from both a MacBook Pro, using the various command line methods, and a Windows 7 laptop, using the Fedora ARM Installer.
The microSD card is fine as I have checked it with h2testw and also, if I copy Wheezy onto it then it boots sans problème. I have also formatted it correctly, using SDFormatter.
Why will Pidora not boot on a RPi 2?
raspbianto an SD card, and running it on Rpi 2.ACTblinks momentarily and then nothing. I solved it by updating kernel and raspberry bootloader by runningsudo apt-get update && sudo apt-get upgradewhich booting it on Rpi 1. Once upgraded, it works fine on Rpi 2 as well as Rpi 1. – dhruvvyas90 Jul 25 '15 at 08:14
