I have an old Maxtor USB 250GB external drive I'm trying to use on the Raspberry Pi 2 running Raspbian. It has the latest updates, upgrades and firmware.
root@raspberrypi:~# uname -a
Linux raspberrypi 4.0.6-v7+ #799 SMP PREEMPT Fri Jun 26 15:50:02 BST 2015 armv7l GNU/Linux
My goal is to format the drive to use it as ext4, but I'm having troubles along the way with error messages. I have connected the drive to Dell server running CentOS 6 and don't have any problem with it there, but I do on the Raspberry Pi 2. Here is an example of what is happening...
I reconnected the drive to the pi. I powered it up and so far the dmesg output looks good:
[28642.569595] usb 1-1.2: new high-speed USB device number 5 using dwc_otg
[28642.670536] usb 1-1.2: New USB device found, idVendor=0d49, idProduct=7000
[28642.670561] usb 1-1.2: New USB device strings: Mfr=1, Product=3, SerialNumber=2
[28642.670578] usb 1-1.2: Product: OneTouch
[28642.670594] usb 1-1.2: Manufacturer: Maxtor
[28642.670610] usb 1-1.2: SerialNumber: XXXXXXXX
[28642.671859] ums-onetouch 1-1.2:1.0: USB Mass Storage device detected
[28642.672627] input: Maxtor OneTouch as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/input/input1
[28642.673106] scsi host1: usb-storage 1-1.2:1.0
[28643.875946] scsi 1:0:0:0: Direct-Access Maxtor OneTouch 0200 PQ: 0 ANSI: 0 CCS
[28643.877462] sd 1:0:0:0: Attached scsi generic sg0 type 0
[28643.878482] sd 1:0:0:0: [sda] 490232832 512-byte logical blocks: (250 GB/233 GiB)
[28644.085084] sd 1:0:0:0: [sda] Write Protect is off
[28644.085124] sd 1:0:0:0: [sda] Mode Sense: 1c 00 00 00
[28644.291701] sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[28645.356829] sd 1:0:0:0: [sda] Attached SCSI disk
Now let's see what fdisk has to say about the drive:
root@raspberrypi:/home/pi# fdisk -l
Disk /dev/mmcblk0: 7948 MB, 7948206080 bytes
4 heads, 16 sectors/track, 242560 cylinders, total 15523840 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0xa6202af7
Device Boot Start End Blocks Id System
/dev/mmcblk0p1 8192 122879 57344 c W95 FAT32 (LBA)
/dev/mmcblk0p2 122880 15523839 7700480 83 Linux
Disk /dev/sda: 251.0 GB, 250999209984 bytes
255 heads, 63 sectors/track, 30515 cylinders, total 490232832 sectors
Disk identifier: 0x762f6146
**Disk /dev/sda doesn't contain a valid partition table**
root@raspberrypi:/home/pi# fdisk /dev/sda
Device contains neither a valid DOS partition table, nor Sun, SGI or OSF disklabel
Building a new DOS disklabel with disk identifier 0x8b811c4f.
Changes will remain in memory only, until you decide to write them.
After that, of course, the previous content won't be recoverable.
Warning: invalid flag 0x0000 of partition table 4 will be corrected by w(rite)
Command (m for help): p
Disk identifier: 0x8b811c4f
Command (m for help): n
Partition type:
p primary (0 primary, 0 extended, 4 free)
e extended
Select (default p): p
Partition number (1-4, default 1):
Using default value 1
First sector (2048-490232831, default 2048):
Using default value 2048
Last sector, +sectors or +size{K,M,G} (2048-490232831, default 490232831):
Using default value 490232831
Command (m for help): t
Selected partition 1
Hex code (type L to list codes): 83
Command (m for help): w
The partition table has been altered!
Calling ioctl() to re-read partition table.
Error closing file
If I do the above to a USB thumb drive, I don't get any of the bolded errors above. When I connect the drive to a Dell server/CentOS and do this, I don't get errors about closing the file.
I don't know what else to do at this point. So I will proceed with doing a mkfs, maybe that will fix it? Just wishing thinking. :-)
root@raspberrypi:/home/pi# mkfs.ext4 /dev/sda1
mke2fs 1.42.5 (29-Jul-2012)
Filesystem label=
OS type: Linux
Block size=4096 (log=2)
Fragment size=4096 (log=2)
Stride=0 blocks, Stripe width=0 blocks
15327232 inodes, 61278848 blocks
3063942 blocks (5.00%) reserved for the super user
First data block=0
Maximum filesystem blocks=0
1871 block groups
32768 blocks per group, 32768 fragments per group
8192 inodes per group
Superblock backups stored on blocks:
32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208,
4096000, 7962624, 11239424, 20480000, 23887872
Allocating group tables: done
Writing inode tables: done
Creating journal (32768 blocks): done
Writing superblocks and filesystem accounting information: done
I guess that looks OK, I don't know if the number of Superblock backups matters or not?
Let's mount it, see what the deal is now.
root@raspberrypi:/home/pi# mount -t ext4 /dev/sda1 /mnt
root@raspberrypi:/home/pi# df -h
Filesystem Size Used Avail Use% Mounted on
/dev/root 7.2G 2.6G 4.3G 38% /
devtmpfs 459M 0 459M 0% /dev
tmpfs 93M 244K 93M 1% /run
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 186M 0 186M 0% /run/shm
/dev/mmcblk0p1 56M 20M 37M 35% /boot
/dev/sda1 230G 60M 219G 1% /mnt
root@raspberrypi:/home/pi# grep sda1 /etc/mtab
/dev/sda1 /mnt ext4 **ro**,relatime,data=ordered 0 0
It's read-only. This is what is happening. I can cd to this drive and try to write to it, but it gives an error that it is read-only. Sometimes after it is mounting it is "rw" but only for a short period of time, like a minute.
Here is the updated dmesg:
[29114.978050] sda: sda1
[29114.979357] blk_update_request: critical target error, dev sda, sector 0
[29363.970597] blk_update_request: critical target error, dev sda, sector 0
[29363.996206] blk_update_request: critical target error, dev sda, sector 0
[29476.782828] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[29480.273343] blk_update_request: critical target error, dev sda, sector 0
[29485.304704] blk_update_request: critical target error, dev sda, sector 243533848
[29485.304763] Aborting journal on device sda1-8.
[29485.593418] EXT4-fs error (device sda1): ext4_journal_check_start:56: Detected aborted journal
[29485.605341] EXT4-fs (sda1): Remounting filesystem **read-only**
This is where I end up. As odd is it seems, if I connect it to the Mac and use Disk Utility I can format and write to the drive as Mac format of FAT32 and on the Dell server/CentOS without a problem.
Is this the drive? Is this the Raspberry Pi 2's Raspbian OS? I have seen postings at the link below that it might be a bug. But it seems like there would be more information or an update about it by now?
https://www.raspberrypi.org/forums/viewtopic.php?f=28&t=103177
max_usb_current=1in/boot/config.txtif you have not yet (see here), reboot, and make sure you are using at least a 2 amp power supply. You need to rule out this issue before you proceed. – goldilocks Jun 28 '15 at 15:27
