On startup, I have ethernet and a 3G modem connected to my raspberry pi. How do I set the pi so that it connects to the 3G modem instead of the ethernet? I am using raspbian.
            Asked
            Active
            Viewed 1,462 times
                    You should specify which operating system you are using. – goldilocks Jun 08 '15 at 16:20
                    @goldilocks I am using raspbian. – FreshTendrils Jun 08 '15 at 16:22
        I got it to work using wvdial, and by modifying a few files. In the rc.local file I used sudo wvdial & to start the modem on startup. After, I used ifdown --force eth0 and ifup --force ppp0 to make sure the 3G modem was being used instead of the direct ethernet connection. In my /etc/network/interfaces file I added iface ppp0 init wvdial. The result is that on startup the modem is used even if the ethernet is attached. As well, if the modem is removed, the ethernet is used, and if the modem is plugged back in, the 3G modem is used.
        FreshTendrils
- 463
- 7
- 13
